KODAKHODAK
Alloy broAre the M7RS aluminum or magnesium?
i purchased my wheels from WRS as well
Good service from them
Thanks guys appreciate the support 🫶Congratulations to @KODAKHODAK with The Panigale V2 Bayliss for being selected as November DUCATImodified bike of the month
DUCATI modified Forum
Hi Kodakhodak, that is beautiful setup right thereFinally installed the RCS19 Corsa Corta Brake Pump & Rizoma Ducati Brake Reservoir, only one minor obstacle was the rear brake light switch, had to cut and join to the original harness plug that came with the Bayliss… other than that relatively easy to do. Took it for a decent ride and brake feels solidNext is track day at SMP in coming weeks 🟩
Unfortunately the switch are different mounting I tried but the actual mechanism block on the V2 is smaller and the RCS19 had bigger pins holes - I thought it would fit but it didn’t 🥲 - nevertheless I just rejoined the wiring was simpleHi Kodakhodak, that is beautiful setup right there
By the way, it might be a bit too late now, but you can take out (pry out) the original brake switch from your original Ducati front brake master cylinder and it should fit to the RCS master cylinder (you have to take out the switch that came with the RCS first of course).
That is what I did with mine.
Nice photos. Cool to have some good shots. Bike looks clean too.View attachment 10821
Great day at Sydney Motorsport Park for my first experience on the Bayliss and the Circuit, not my first track day but new to this combination. The Bayliss had a few minor issues with down shifting but this was resolved later in the day once i spoke to a few guys including @Andy7 - Cheers for saying hello and for the tips. Few happy snaps from the local photographer at the track. Keen to get back with more confidence!
cheers for the links going to give the Racetorx unit a go and get my service team where I work check for any errors on the quick shifter unit, if it keeps failing might need a new one from ducati under warrantyI purchased Cordona unit because @HKMP7 recommended it and he had good experience with it for my V4.
Here is the link for Cordona unit for V2: Item 420Evo-Spec-V2 - Ducati Panigale V2 Quickshifter - Blipper | Cordona Precision Technology
If you want to buy Cordona, you can buy direct from the US/Canadian importer, and I can PM his information to you if you want me to.
However, I just noticed Domino also made one for V2 and here is the link: Kit Quick Shifter for Ducati Panigale V2 97.4087.13-00 | Domino Srl & Tommaselli
ill try a few things this week as I’d like to see if the Racetorx helps will set the tyre calibration on default and do another stress test if that fails then it has to be a shity QSMy bike was doing the exact same thing. Sometimes it would work, but mostly it would not. Upshift always worked fine.
You can always manually blip the throttle to get it to downshift. I did that all the time on my 1199 since the QS was up only. Not a long term solution.
You can ask your dealer to perform the DQS test, which will show them if the QS is working, you can also with the dealer tool or an OBDStar iScan you can see the voltages the QS is putting out. The three wires are +5v input, ground and signal direct to the ECU. At idle, the signal wire will read +2.5v. For an upshift, +3.8V and for a downshift +1.8V. When I checked with the iScan, I could see the ECU was reading the correct voltages. Only setting the tire calibration to default fixed it.
Go into the menu for tire calibration and set it to default. Try using it on default without performing a new tire calibration.
it supports the quick shifter shaftWhat is a Racetorx?
