this light button is the new Daylight button, you can toggle on or off - High beam is on the the left side as normal, will upgrade that side soon swell to button switch systemIs the high beam normally on the right side on the V2? On the V4 it’s a goofy lever switch on the left that I constantly turn on by accident.
hey mate what clutch pump lever would you suggest to match the brake side that have ordered?Actually, I just realized your V2 used the M4.32 caliper (32mm piston diameter in the caliper) which is different then the V4 Stylema calipers (30mm piston diameters).
So your V2 will need the larger master cylinder which is RCS19 or RCS 19 Corsa Corta:
RCS19:
110A26310 RADIAL BRAKE PUMP BREMBO RACING 19 RCS 110A26310
or RCS19 Corsa Corta:
110C74010 BREMBO RACING RADIAL BRAKE PUMP 19RCS 19 RCS CORSACORTA
The Panigale V4 used RCS16, also the 959, however, Brembo Panigale V2 configurator did not show which model is the right size.hey mate what clutch pump lever would you suggest to match the brake side that have ordered?
They responded but not sure what they mean I need buy the response:The Panigale V4 used RCS16, also the 959, however, Brembo Panigale V2 configurator did not show which model is the right size.
Perhaps it's best if you email WRS.it and asked which model is the best fit, here are the choices:
Motorcycles Parts for Honda Ducati MV Agusta Kawasaki Yamaha Suzuki
The mounting bracket for the stock Clutch Fluid Reservoir and the RCS16 model is not the same, so you might need to make either a custom bracket or buy some after market fluid reservoir.They responded but not sure what they mean I need buy the response:
Dear Frank, this is the recommended clutch master cylinder by Brembo for the Panigale V2. It fits also the Bayliss edition. You may have to do some adjustments to adapt the OEM clutch fluid reservoir and for the clutch hose. You'll also need a hydrostop (kick stand and gear turning off the bike): -> 0626MQ20 IDROSTOP SHORT BREMBO 10X1 UNIVERSAL Thank you Best regards
DID 520 ERV7, cheapest MOTOGP parts available commercially..... excellent transient response...Ordered a New DID Gold Race Chain and went up a tooth on the front sprocket from a 14 to 15 - anyone done these mods to there ducati, what did you notice?
Pretty sure that’s what I have ordered via workDID 520 ERV7, cheapest MOTOGP parts available commercially..... excellent transient response...
Is the Hydrostop switch cable easy to instal? where does it screw into, the clutch lever?The mounting bracket for the stock Clutch Fluid Reservoir and the RCS16 model is not the same, so you might need to make either a custom bracket or buy some after market fluid reservoir.
I believe Brembo also made some bracket and clutch reservoir for RCS model. But try to buy the RCS16 Clutch MC first and then review if you need to modify the bracket or not.
Alternative way is to buy the Motocorse reservoir for both clutch and brake RCS MC:
Regarding the Hydrostop switch, you also need it for ease of install because the RCS Clutch MC does not have any "switch" unlike the RCS brake MC. And our brake have switch for safety start when you are in gear (not neutral) and want to start your bike. So I recommend you to buy it also. On my bike, I used a Kohken Japan manual switch but it's more complicated to install. this Hydrostop is easiest. In fact I will buy it once I buy more things from WRS just so I can have it as a spare in case my Kohken manual switch fail someday.
It is a replacement for the Banjo BOLT. The Bolt that connect the clutch hose to the clutch master cylinder.Is the Hydrostop switch cable easy to instal? where does it screw into, the clutch lever?
Hey do you have a website link to look up this OEM sticker kit? Cheers FrankThat wheel is going to look super nice with your Bayliss V2,
I also just check the V4S catalog and I believe this is the Red Vinyl Sticker Part#:
Front Wheel: 4381F071A
Rear Wheel: 4381F061A
I think I also will buy those Red sticker for my 998 project Marchesini Wheel![]()
Hi Frank, you can look for the parts here: Superbike Ducati motorcycle # DUCATI Online Genuine Spare Parts CatalogHey do you have a website link to look up this OEM sticker kit? Cheers Frank
The brake ducts are the standard 100mm spacing, so as long as your calipers match, I see no reason why they won't fit with your forks as they work with both Showa and Ohlins and I'm not sure the fork bottom castings on your V2 are substantially different. Here's mine.View attachment 10372
Anyone know if these can be modified to suit a V2 Panigale, these are by far the best looking brake ducts i can find besides the banana shape CNC Racing - cheers in Advance if someone can help
Ahhh ok, well I might just purchase a set and see if it fits cheers for the updateThe brake ducts are the standard 100mm spacing, so as long as your calipers match, I see no reason why they won't fit with your forks as they work with both Showa and Ohlins and I'm not sure the fork bottom castings on your V2 are substantially different. Here's mine.
