Hello KodakHodak,Hey lads, I just bought the jet prime button for the throttle side for my V2, question is many recommend the Brembo RCS 17 for the standard calipers, it would be an overkill to got the RCS19 brake pump lever.
Should I stick with the RCS17, what’s everyone thought experience with this Brembo product
cheers
Frank
so the one I posted would be perfect for my V2Hello KodakHodak,
It's not about higher spec (overkill) but the RCS17 has the right piston diameter to drive your brake caliper without causing any "wooden" feel from a too large master cylinder which will happen if you use the RCS19.
The effort to push is less with RCS17, and the "feel" is also better with RCS17.
If you would like higher spec (without too much price differences) then us the RCS17 CORSA CORTA. (Corsa Corta is an improved and newer version of the RCS line).
I personally use RCS line (Corsa Corta or not) come with the brake light switch, plus you can also swap your current Ducati brake light switch directly to the RCS line so no connector swap or wire splitting required.
Cheers broActually, I just realized your V2 used the M4.32 caliper (32mm piston diameter in the caliper) which is different then the V4 Stylema calipers (30mm piston diameters).
So your V2 will need the larger master cylinder which is RCS19 or RCS 19 Corsa Corta:
RCS19:
110A26310 RADIAL BRAKE PUMP BREMBO RACING 19 RCS 110A26310
or RCS19 Corsa Corta:
110C74010 BREMBO RACING RADIAL BRAKE PUMP 19RCS 19 RCS CORSACORTA
I am working on it will be out this weekend to to get that 1000km - service is booked for the 20th this month, still only Revin it around 6000rpm by November she will be ready for full noiseNice one, I’ll try get out there on the 20th as well. Might be my last one for the year after having a quick look at the available dates.
Hope you’ve been wringing it out on a few bendy roads!
thanks bro, sometimes you have to show ducati how it’s doneThat Carbon Fiber Swing Arm Cover is really nice and make your bike looks even more special. I am surprised Ducati did not include it from the factory since this is the Bayliss ediition.
Just ordered the RCS19 Corsa Corta today from workHello KodakHodak,
Nice. I wired mine when I replaced them after my last track day. The double wrap is key to the technique. My clutch side was a little wonky and loose. The Cycle Gear shop near me had the black and titanium 717s in stock.View attachment 10178
Wire locked my Grips Tonight, preparing for a track day Nov 20th in SMP Australia
Hello KodakHodak, Bonamici Racing made a remote adjuster, you can buy from WRS: 0043 REMOTE ADJUSTER BONAMICI RACING FOR BREMBO BRAKE PUMP RCSView attachment 10339
Thought id change the start buttons on the V2, never liked the stock configuration and with the new Brembo RSC19 Brake Pump to arrive this will tidy up the right hand side of the bike. Has anyone added the adjustment brake cable on the left side that connects to the Brembo Brake Pump, I have noticed the SP2 V4 has them installed from factory what brand would this item be?
