Ducati Panigale Bayliss 1st Championship 20th Anniversary - Project Build
Wasn't happy with the Ribbed Clear Eazi-Grip on the black plastic, so I went with the other option and bought 2 sheets uncut so that I can custom shape to suit this section on the V2, I think its much better suited and from a distance its not as noticeable but works effectively to eliminate scratches and provide grip if needed. Tomorrow is its first service and NEW DID chain and Sprocket get installed.
Question has anyone installed these brackets from Rizoma for their Brake and Clutch Reservoirs - looking at the new RCS19 Cross Corta the OEM bracket won't suit and seeing a video on YouTube shows the bracket can be fixed to the bar end towards the front shock/steering clamp.
On the Panigale V4, the handlebar ends near the fork is a big screw/bolt that tightened the handle bar to the bar clamp so we can't use this Rizoma brake fluid reservoir bracket... is the V2 handlebar tightened differently? (maybe with pinch bolt like the old 998?)
Ohhh good point, hrrrmm wonder how I can mount mine to retain the factory fluid reservoir?
Anyone know what the part no. for this bracket is, saw on forum elsewhere saying is Ducati Performance brand
topolino
Had a set of these on my 1199 when I fitted some Rizoma reservoirs. I am not sure they will work on the V4 however due to the allen bolts/caps in the end of the handlebar tubes. The 1199 just had plain end caps fitted plus the ends of the V4 tubes are threaded internally. You COULD drill and tap a hole into the centre of the existing V4 plug, ditch the rubber sleeve and conical nut/washer and just bolt the bracket to the end cap as a way around the issue.
Have ordered the Rizoma bar end mounting brackets apparently they are suited for the V2, will also share information once installed.
mr. 1299
just installed these on my 1299. i had to modify they angled bracket that the res mount on as my AEM res are a little different. they mount right in the inside end of the handle bars. so far so good.
CNC Racing goods arrived to tidy up the rear end of the Bayliss now to get my work to fit and install - standby for finished results
Anyone know how to install this IDROPSTOP to the clutch side for my Brembo RCS lever?
Information i got was this: "Need to know where i screw the threaded part into?
Dear Frank, this is the recommended clutch master cylinder by Brembo for the Panigale V2. It fits also the Bayliss edition. You may have to do some adjustments to adapt the OEM clutch fluid reservoir and for the clutch hose. You'll also need a hydrostop (kick stand and gear turning off the bike): -> 0626MQ20 IDROSTOP SHORT BREMBO 10X1 UNIVERSAL Thank you Best regards
Finally all my new Rizoma Brake & Clutch Reservoirs + brackets arrived - any tips on to drain the OEM fluids ?
For me, when I am draining brake fluids first:
a. Have a bucket of water with several cloth towel already wet with water covering the area where the brake fluid potentially spill (especially painted finished area) to prevent the brake fluid from eating the paint
b. Use a syringe to take out the fluid from the old reservoir
c. Drain rest of the fluid from the bottom (either from brake caliper bleed valve or from the clutch bleed valve) into small hose to drain tube
d. Once most of the fluid in the old reservoir almost emptied, get some paper towel to "sponge" the rest of the fluid in the old reservoir, then remove it and replace it with the new reservoir.
That is replacing your current banjo bolt on (the bolt that hold your clutch hose to the clutch master cylinder).
Finally pulled the pin on NEW set of Marchesini M7RS Genesi Wheel Set for the Bayliss in Matte Black, WRS.it had 15% discount and been eyeing them out for over a few weeks now. Not sure how the Matte Black will look on the Bayliss ill see when the wheels arrive and the Bayliss in less than 10 days away to land at my work, exciting times. Not long till I can start putting the project all together with everything that I have mentioned so far.... Question for the forum, any idea what the OEM Bayliss Rims would be worth? AUD $$$
Are the M7RS aluminum or magnesium?
i purchased my wheels from WRS as well
Good service from them
F I N A L L Y, it landed this week and whilst it’s at work, managed to bolt on a few goodies… we just waiting for a package from Ducati to arrive then I’ll get the boys in service to bolt the new wheels on and get it home for its maiden ride! Can’t believe it’s been 12 months wait to order this beauty, definitely had a moment tonight just soaking it all in! Few pics from the showroom floor of where I work… 🫶
Very nice
