I decided to make sure the Motocorse Titanium bolts for the exhaust heat shield works with the Motocorse 60.5mm Titanium Exhaust Piping and of course the Carbon Fiber heat shield it self:
Well... right away I notice something is not right
The hole location is way off... so this Carbon Fiber Heat Shield by CM Composite (now speed carbon) was the right fit for the latest 998 Termignoni Piping, however, the Motocorse was made following the 998RS or the older 996 type bolt spacing, thus the reason...
8cm spacing on the Termignoni vs 13 cm spacing on the Motocorse:
Which means, I got to order another Carbon Fiber Heat Shield... but the good news is I can order the MS Carbon version now
... will take a few weeks (hopefully)...
in the meantime test fit just with one hole:
Yap, of course it is gorgous... oh, will also need to add spacer (and some heat shield washer):
Then I found out, that i need to buy one more of this Motocorse Titanium Bolt (around $64 each... but well they are so beautiful so what can I do... but to buy them
)... so I need to buy one more for the bolts that connect the 2 Motocorse exhaust piping:
Yeah baby, you are so gorgeous
Ok, now I now the problem and solution for Motocorse, now time to move on to Rizoma... meaning test fit the Rizoma mirror adapter for Ducati 1198 (yes this is for 1198, so I might need to do more "adapting" when I install it onto the front fairing of the 998, but I am sure it's doable
Notice, that the Rizoma Veloce L rear view mirror currently connected to the Panigale V4 Rizoma mirror adapter:
First unpacked the Rizoma mirror adapter for 1198 and assemble them:
And yes, they FIT PERFECTLY
, so someday when my 998 is ready, this will be the Rear View Mirror on it
By the way, I am now thinking of painting those black upper and lower part of the rear view mirror housing in the same Red as the 998... but I am not sure yet... so I will decide once I install them on the bike.
Next are the switches... so I buy so many switches because initially I was having a hard time finding a brand new switch since Ducati no longer make them... (eventhough I finally able to find New Old Stock, but it was one of the hardest parts hunting I ever done)...
Ok, now, I bought a switch from an eBay seller in UK... his switch is quite nice and from the 916 generation thus the "unique symbol/lettering". However, the lower housing pin had been filed/grind down, must be to be used with aftermarket handle bar without the hole for this pin (anti rotating pin)...
Well, I am not happy with this so.... I will use the lower housing from the original switch that came with my 998 and switch it around (swap maybe the right word, swap it around
)... but first, I got to install the starter button cover that had been rejuvenated with USMC Red Cerakote
The left switch is the original switch from my 998, the right switch is from UK eBay seller and it came from an old 916... but amazingly, the old 916 is in better condition than the newer 998 switch.
This after I install back the Red Starter Button now in USMC Red Cerakote finish, notice how brilliant it is:
Now, I am comparing my old 916 switch with the brand new ST4 switch. Yes, the left switch is a brand new ST4 switch... wait why Ducati ST4?....
Well... Ducati no longer make the right switch for 916/996/998... but I found this ST4 switch on sale on eBay someday... brand new condition of course... Initially I was worry the wiring would be different, but after taking a look at the socket style, they are exactly the same.
So even if the wiring is different, I can easily swap the wire if I have to. Turn out, the different between an ST4 switch to a 998 switch is just the ST4 came with a much longer wiring harness hahaha
You guys don't know how many nights I spent, browsing on the internet just to find a brand new right switch for 998... it drive me insane... but the solution is so simple, just buy an ST4 switch and they are the same...
Well, if anyone read this, the ST4 switch is almost run out too. so you guys better hurry if you want to buy a new switch for your 998
Here is the picture showing the different in wiring length:
But even when I compare to the brand new ST4 switch, I still like the 916 switch better, so I will use the 916 switch for this build (and the ST4 switch for spare). You can see on the picture below on why I like the 916 switch better.
Oh by the way, I cleaned that 916 switch very well, that is why it look brand new again. It wasn't this clean when I just bought it from that UK eBay seller
Next, pack them in a plastic to make sure they are safe until I need them:
Next, the tough choices of choosing between the collection of the left switches I have
Well, no, it wasn't that hard to choose...
so the left is the original switch that came with my 998 and it is USA version meaning, headlight always on, no switch to turn off the headlight,
in the center is the switch also from the same eBay UK seller, which again came from an old 916 that have headlight turn on/off switch, and the right switch is a brand new switch for 998 UK version with headlight turn on/off switch
Of course I will NOT use the left switch since it is US version without the ability to turn on/off the headlight so it will be going to eBay for sale soon
And again compare to a brand new 998 switch... I still like the older style 916 switch so for this build the 916 left switch will be used and the brand new 998 switch will be for spare:
Ups, I hit the limit for posting picture so will continue below:
