Now it is time to TEST to make sure these "MOTORSPORT Grade" wires work by first connecting all 3 wires (Ground, Indicator and Turn Signal)
And yes, they worked:
First, both left and right INDICATOR Lights (White LED):
Then test the Left and Right turn signal, and again worked:
Now I need to add the Rizoma Adapter to install these Rizoma Corsa indicator / turn signal combo onto the MS Production Corse (larger size) Intakes, with Titanium ProTi bolt of course:
Done:
But wait, I forgot,... I need to install the Rizoma Corsa onto the Rizoma Adaptor first before installing the Rizoma Adaptor onto the MS Production Carbon Intake.
Use the ProTi Titanium Nuts of course:
Installed:
Run the wiring inside the MS Production Intake:
Out to the other side of the MS Production Carbon Fiber Air Intake ready to be connected to the supply wire harness:
Done:
Installed:
