Ducati 998s FE Final Edition (REPLICA but MODIFIED FAR BEYOND the Original) Build Thread
Now it is time to TEST to make sure these "MOTORSPORT Grade" wires work by first connecting all 3 wires (Ground, Indicator and Turn Signal) :ROFLMAO::
And yes, they worked:
First, both left and right INDICATOR Lights (White LED):
Then test the Left and Right turn signal, and again worked:
Now I need to add the Rizoma Adapter to install these Rizoma Corsa indicator / turn signal combo onto the MS Production Corse (larger size) Intakes, with Titanium ProTi bolt of course:
Done:
But wait, I forgot,... I need to install the Rizoma Corsa onto the Rizoma Adaptor first before installing the Rizoma Adaptor onto the MS Production Carbon Intake.
Use the ProTi Titanium Nuts of course:
Installed:
Run the wiring inside the MS Production Intake:
Out to the other side of the MS Production Carbon Fiber Air Intake ready to be connected to the supply wire harness:
Now time to pay attention back to the Speedometer. First, I found this new but old stock real Ducati Carbon Fiber speedometer surrounds (to someday replace the foam):
Test fit them, but I still need to refinished them in Matte Clear, so it will become DRY CARBON looks:
First problem, the Neutral Light Indicator is NOT bright enough, so I am replacing with brighter LED:
Before and After
Oh, talking about light, I bought this dual-function tail light and brake light. Soon I will post why:
I also purchased these custom Y-Splitter SuperSeal connectors from a vendor in Italy to be use with the 2 lights above... I think you might already know where I am going with this:
