More ProTi weekend today
Attached the ProTi bolts and Nuts on the radiator bracket, Radiator itself, ABS mounting nuts and Fuel Filter Canister Bracket:
Remove the Front Exhaust Manifold to gain access to all the bolts behind it,
Before and AFTER
Replacing the NUTS on the Steering Stopper to ProTi so now all the bolts on the lower triple clamp had been change to ProTi Titanium:
Then replace the remaining M8 lower front crankcase bolts to ProTi (torque it to 25Nm):
Replaced the Oil Plug bolts on both Front and Rear Cylinder Head with ProTi Titanium (also replace the cooper washer),
Before and AFTER
and on the REAR cylinder head too:
Replace the bolt on the Oil Hose from the Oil Cooler with ProTi Titanium Bolts too:
Measured the stock bolts on the Starter Motor and M6 bolts for the front lower crankcase, and after this, I think I already bought all the bolts on the engine.
The only thing I can't change is the NUT for the exhaust manifold since it require an M6 NUTS with 8mm hex head, and ProTi does not make M6 nuts that small:
Before and AFTER
Before and AFTER
