Another Weekend Update:
Installing the Lieb Carbon Seat Pad Cover, however I decided not to use the sticker that came with the package because I don't plan to ever took out the Carbon Cover anymore.
A little bit of trouble when I found out the black glue that came with this Carbon Seat Pad Cover had dried and become solid since I bought this cover a long time ago, luckily I have some left over from installing the Carbon Belly Pan so everything is good.
Currently wrap it with some masking tape to help hold the carbon while waiting for it to cure and tomorrow I will install Ducati Sticker
Then I install the Lieb Carbon Lower Subframe cover:
This is quite complicated, since you need to do many small things, like installing the spacer for the locking mechanism:
Took out the rubber bushing from the stock cover and move it to the Carbon Cover:
Then took out the tie-lock clamp holder from the stock cover and move it to the Lieb Cover:
Then secure the GPS cable extension with the tie lock:
Then, make sure you attached the locking mechanism CABLE before you install the Lieb Carbon Cover (I learned the lesson
), however, I forgot to take picture of this step, but it's not hard.
Then, I use Ducati Original Nylon Washer on every ProTi Titanium Bolts that I used to secure the carbon cover to make sure it will not crack the carbon fiber over time.
Again, the Fit and Finish of Lieb Carbon Product is AMAZING
and installed pictures below:
After this, I will install the side (left/right) Lieb Carbon subframe cover
