Replacing more bolts with ProTi Titanium Bolts:
First, I replace the bolts that hold the secondary air cover on the rear cylinder head, and this is comparison between stock bolt on the left and ProTi Titanium bolt (gold color) on the right:
I also replace the main 4 large bolts that hold the cylinder head itself with ProTi Titanium Bolt in silver color to better blend with the Magnesium color cover.
I need to purchase 2 Ducati parts since the ProTi bolt had different rubber. The 2 Ducati parts were the washer and the rubber bushing/seal:
Left is the original Ducati bolt assy, center is ProTi bolt assy, right is the rubber bushing and washer :
I cut the ProTi rubber bushing out:
Then I install the Ducati rubber bushing/washer. The rubber grease is needed to be applied to the rubber bushing, so the rubber bushing can be inserted into the ProTi bolts easily.
Then apply more rubber grease to the outside surface of the rubber so it can be inserted into the cylinder head smoothly:
This picture show the left 2 bolts were still the original Ducati cylinder head cover bolts and the right 2 bolts already use ProTi Cylinder Head Cover Titanium Bolts
and picture below shows every bolts had been replaced with ProTi Titanium Bolts. Notice the COILS also have ProTi Titanium Bolts:
Then, I replace the front magnesium subframe upper ProTi Titanium Bolts with ProTi Titanium Bolts that have larger diameter head to make it looks much better.
This is BEFORE picture:
Bolt head diameter comparison:
And AFTER picture, notice how the larger head diameter make it looks much better:
Then I replace the gear position sensor bolts with ProTi Titanium Bolts:
Last, I replace the Knock Sensor bolts with ProTi Titanium Bolts. This is the original bolts:
And the ProTi replacement installed. This bolts were below the throttle body/airbox assy so it is not visible, but I just want to replace them since I am committed to replace every bolts (possible) with Titanium equivalent:
