Hopefully, I can continue installing the clutch this weekend. I was busy with work and house renovation.Love the all out build. Any new updates?
Very nice work HTaking advantage of this 1 day middle of week holiday I decided to continue with the rear mudguard:
I painted the very bottom part of the metal factory chain guard reinforcement bracket black to it won't stand out too much (the rest of the surface was cerakoted). Using blue painter's tape to cover the surface that I want to keep in cerakoted color:
Here how it looks after I took out the blue painter tape:
I also painted the other side silver since it was scratched when I make the hole elongated:
To ensure, the metal bracket really become one (increase reinforcement strength) with the carbon chain guard, I apply epoxy:
I then joint both part together:
Finally, install it to the swing arm. Please note this is the full mudguard/chain guard combo by Ilmberger carbon:
Also install the front bolt using ProTi Titanium as always:
It also clears the larger 190/55 rear tire now (I made that hole a few months ago):
View attachment 13860View attachment 13861
Also clear the 60.5mm Motocorse Titanium Exhaust:
View attachment 13862View attachment 13863
Next is replacing the bolt that hold the rear brake line cover with ProTi titanium, but turn out the titanium bolt that I bought was too short, so I will buy a longer one, but for now, it can hold it:
View attachment 13864View attachment 13865
to Titanium:
View attachment 13866View attachment 13867
Here is how the overall look:
View attachment 13869View attachment 13870
Interesting, I to had the same experience with my hose kit from CG.It to was short and ordered the Samco oil hose same as you.The next step is to install the STM Billet Crankcase breather full assembly. I already installed the base part of it a long time ago, and I forgot whether I had tightened it or not, so I re-tightened it again with a torque wrench.
Add some rubber grease to the O-ring:
View attachment 13873View attachment 13874
Insert the top onto the base:
Get the Circlip:
Lock it in place:
Now it is ready for the installation of the custom silicone hose from Corsa Garage that I bought as a set with the 996RS replica carbon fiber crankcase breather box... well at least I thought so...
First I routed the custom silicone hose, and it was very tight also need to avoid that giant 60.5mm Motocorse Titanium exhaust header:
Then I add Grease A:
I insert the top portion of the custom silicone hose:
Routed and aligned the Corsa garage logo on the silicone hose:
And somehow it is about 1 inches too short:
Yap, there is no way it can fit... it is too short... worse is, it is almost impossible to take out the hose from the nipple at the carbon crankcase breather box, so I have to cut the hose (the hose diameter is also super tight)... so I just waste it away...
The good news is, I ordered the SamcoSport ProFuel hose to replace this Corsa Garage silicone hose. The SamcoSport ProFuel hose has an inner lining made out of non silicone so it will not leak the oil from it's pore like a regular silicone hose would (after long use of course)...
I also ordered in the custom order Samco Vintage Black wrap finish which should make it look like a Ducati factory hoses.
I was tempted to also replace the longer Corsa Garage silicone hoses from the top portion of the crankcase breather to the airbox, but for this moment, I am going to keep the Corsa Garage (unless later it turn out to be way too short too), because that one had a 90 degree bend,... but I figure it out later once I install the airbox...
Get the Circlip:
Lock it in place:
Hi @Ducabike998Interesting, I to had the same experience with my hose kit from CG.It to was short and ordered the Samco oil hose same as you.
Strange….
Long hose fits fine with plenty of extra length.Hi @Ducabike998
I think Corsa Garage was using the 996 engine to measure it, not the 998 Testastretta engine block...
How about the longer hoses? Were you able to fit it to your airbox? or was it too short too?
Looking good HI decided to further setup the alignment of the rear Master Cylinder Brake Lever by adding the ProBolt Drilled Titanium M6 washers:
It will spaced out the rose joint further:
Lock it using the ProTi Titanium Bolt:
Also add ProBolt Drilled M10 washers (double stack) to space OUT the whole rear master cylinder bracket:
Test fit on the bike:
View attachment 13981View attachment 13982
Next setup the right rear set with the new thicker aluminum spacers:
It allow the 996RS exhaust heat shield behind the right rear set to clear the super large 60.5mm Motocorse Exhaust piping (barely):
View attachment 13984View attachment 13985
Yeah, look bithchin:
Unfortunately, when I test by sitting on the bike, the brake lever is way too high in relation to the foot peg height, so I will have to modify the brake lever further (later), but in the meantime, they all looks PERFECT:
View attachment 13987View attachment 13988
I done so much more this 4th of July weekend, will update more soon...
