Today, the 2006 999S Crankshaft arrived back from Ben Fox of
Fox Performance - Ducati Crankshaft Balancing Specialists
and although it took longer than originally plan due to multiple factors that were outside Ben's control, however, the result is nothing short of BREATHTAKING.
It was so worth the wait
I really recommend everyone to trust their crankshaft work to Ben Fox, who SPECIALIZED and FOCUSED on Crankshaft works
As usual, let's start with unboxing picture
Then let's do some BEFORE (left pictures) and AFTER (right pictures):
In this first comparison, notice that Ben DRILLED 1 more "dimple" to lightened and balanced the crankshaft, but take a look at that REAL MIRROR Polishing:
Second comparison:
The KNIFED EDGING is really smooth and of course "MIRROR POLISHED"
Third comparison below, you can see how ROUGH the original crankshaft with many PORES and HOLES on it's surface, the jagged edge and compare to the AFTER Ben Fox treatment of MIRROR POLISHING with no jagged edge anymore.
Yes, once you installed the crankshaft inside the crankcase you won't be able to see the WORK OF ART Mirror Polishing anymore, however, I know and you know and everyone who see this documentation know that the crankshaft had been PROPERLY work and MIRROR FINISH to PERFECTION,
and it is part of the satisfying experience.
Now, let's compare the weight between this 2006 999S Crankshaft done by Ben Fox to the 2005 999S Crankshaft done by Boulder Motorsports:
First just the 2006 999S Crankshaft only without conrods by Ben Fox:
And on the left picture below, I am adding the Carillo STEEL Connecting Rods to the 2006 999S Crankshaft lightened balanced knife-edged polished by Ben Fox, while the right picture is the 2005 999S Crankshaft already installed with the TITANIUM Pankl connecting rods lightened balanced knife-edged polished by Boulder Motorsports:
As you can see, the 2006 999S Crankshaft by BenFox is actually lighter even though it is paired with the heavier STEEL Carillo connecting rods.
Now, please note that we the addition of the bearing to install the connecting rods, the 2006 999S Crankshaft with Carillo STEEL connecting rods will eventually (I suspect) be a bit heavier than the 2005 999S with the Pankl TITANIUM Connecting rods...
but the fact that the Titanium Pankl is quite lighter than the Carillo means, the 2006 999S crankshaft must be already lighter from Ducati factory, plus the extra worked by Ben Fox.
I also love the fact that the STEEL Carillo connecting rods should be more bulletproof compare to the lighter Pankl Connecting rods, so for this engine, I am 100% decided to go with the 2006 999S Crankshaft by Ben Fox even though it will be a tad heavier when those conrods are installed.
Still, for the RACING high rpm, fastest response, I suspect the 2005 999S Crankshaft by Boulder Motorsport will be more responsive due to the lighter total assembly (with the bearing) and that lower inertia of the Pankl TITANIUM Connecting Rods though...
I have more pictures below:
