This weekend, is Flywheel/Generator weekend
Well, before I go there, I install the correct and original Woodruf key for the layshaft timing belt. There are 3 woodroof keys on this layshaft timing shaft.
2 under the those 2 timing belt rollers (left side) with it's own shape/part# and 1 that I mark in RED on the right, that have it's own part#(unique shape).
However, Ducati now don't produce these 2 types of woodruf key anymore but replace it with 1 part#(shape) that was either too short in length or too short in tall ...
(maybe it work, but not as good as the old 2 woodruf keys originally design for this. So I manage to find some New Old Stock Woodruf key and make it perfect.
Then, I prepare the K-Bike Flywheel, the clutch plate, and the 1 way starter clutch, also a can of oil:
I test stack these 3 parts together:
I then test stack them with the generator wheel:
I also use the old bolts to see how I can press fit all of them together:
Then start press fitting them together by tightened all the old bolts:
I compared them with the stock flywheel (brand new assy.) that came with both clutch plate and 1 way clutch. This is in case I found the K-Bike flywheel is too light for my engine configuration.
Then some weight comparisons:
Below is brand new flywheel with starter clutch plate and 1 way starter clutch:
and this is with K-Bike Flywheel (much lighter) like 50% lighter. K-Bike also produce an even lighter flywheel, but I worry it will make the engine easier to stall, harder to start during cold weather (need to increase idle much higher to prevent stalling), plus, it will be jerky which is not desireable during cornering and during wet weather. Not that I will be riding this bike anytime soon, but just in case...
Please note, that my engine will have lighten crankshaft, lighten primary gear, lighter piston, also this lighter K-Bike flywheel and also very high light cam from 999R Camshafts...
Plus, the main differentation is I am not Alvaro Bautista with his world class reflex and response
Next, I noticed that the 999S generator wheel (that came with my used 2005 999S engine) have different shape then the brand new 998 specific generator wheel.
The 999S Generator has slightly different wire length compare to the 998S Generator so I decided to purchase a brand new set of 998S Generator for this 999S engine.
But turn out the 999S Generator wheel is lighter then the 998S Generator wheel:
This is 998S brand new Generator wheel:
and this is the used 2005 999S Generator wheel:
What funny was, I just sold this used 999S Generator flywheel and generator set on eBay just yesterday (will ship them to the buyer today), plus I believe, the extra weight of 998S flywheel will again help to tame the rough idle and stalling tendency of using a high lift 999R camshaft so I will still choose the 998S heavier generator flywheel anyway.
From what my engine builder told me, the late version of US 999R engine had their camshaft swap back to the lower lift 999S camshaft because customers in US were complaining how 999R were easy to stall during traffic. And mine here is the REAL high lift 999R camshaft
Ok, now it's time to tightened the stack for real using ProTi titanium bolt.
On the left is ProTi M6 with lower profile head, the black bolt in the center is the stock steel bolt, and the right is the ProTi M6 with normal profile head.
As you can see, I will need to use the ProTi M6 with lower profile head and also Lock 2 (Loctite 243):
Installed and Torque to 13Nm:
Then install the spacer, roller cage bearing and washer:
Then test fit to the 999S original crankshaft and Pankl Titanium con-rods (that I will not be using for this build):
