Thanks DucRider_NL for the engine table above.
The original engine that came with my bike is the DieCast 998 US Version and NO Deep Sump.
That is why I decided to replace it with a 2005 999S engine from Japan (same as EU) that is Deep Sump and has Pankl Ti Con-Rod but it is a Die Cast with super low mileage.
I was specifically looking for a 999S engine from 2005 and newer because starting 2005 and newer the 999S came with improve cylinder head design, Pankl Ti Con-Rod and LIGHTENED Crankshaft from the factory.
Yes, if you look at the picture of my stock 2005 999S crankshaft BEFORE the balance/polish/knifeedge and compare it to several 999S used crankshaft now available on eBay from 2004 and older engine, you can see that my stock 2005 999S crankshaft from the Japan engine have a much smaller profile because it is lighten version.
Back to about the current engine configuration:
I found a Brand New Old Stock 2006 999S Crankcase EU Version so the CrankCase in this build is Brand New but it is a Die Cast. I didn't want to use 999R engine because the Pistal over bore kit is available only for the 999S. The 999R complete engine is also harder to find in low mileage and not abused condition.
I also purchase brand new cylinder block and piston, STM Dry Clutch, Generator, Starter, Primary Gear, Ducati Performance Lightened belt gear, Oil Pump, both side cover (clutch and generator), Water Pump, cylinder block/head side covers, Cylinder head magnesium Cover and now the crankshaft and con-rod (Carrillo) will also be new.
So in the end, the only parts that I used from that 2005 999S Japan engine will be the cylinder head and gear box.
Now, there is one parts that will increase the performance maybe another 15hp (according to the engine builder) that I just decided to upgrade and it is from a 999R. I will post it here once I place the order
