Also... I mention 3 things arrived above... which means 3 packages...
and here are the 2nd package:
I had been trying to look for a BRAND NEW 998 radiator (different than 996/916 radiator, and also different than 999 radiator). Since 998 were only produced as year 2002 and later 2004 (very small number might be 2003)... so there are NOT much radiator specific for 998 was available in the first place.
And Ducati had stopped producing this 998 radiator maybe 10 years ago.
So last year, I gave up searching for a BRAND NEW unit and just purchase from FEBUR.
The issue with the FEBUR version was, they never made one for 998...
Ok let me explain the different between original radiator from Ducati for the 998, that it have 2 electric fans while 916 and 996 only 1 electric fans. The 998 radiator also slightly larger than 916/996 but they both have the same mounting to the frame of the bike.
The 999 is the same with 2 electric fans but it have an water fill nect/inlet directly on the radiator while the 998 use hose and remote reservoir inlet.
Back to Febur...
They made one model for the 916/996 street version but not for 998. So I provide them with a template for dual electric fans mounting and although they are quite close, but it is not an exact fit (hard to just simply give drawing of mounting tab by hand drawing).
Another problem was, I guess Febur forgot that the 916/996/998 all have inlet and outlet pipe on the left side of the radiator, and somehow Febur made me an inlet and outlet on the left and right side.
Well, this means I will need to further customize the piping if I want to use my Febur radiator.
The Febur seems a bit thicker than the original 998 radiator (the used radiator that came with my bike)... but all this customization... well I can do it, but...
A few weeks ago, I somehow "stumble" into this BRAND NEW 998 original radiator with original brand new 2 electric fans for a decent price of about $1,000 only....
So I decided to purchase it so now I have an alternative. Either just a bolt on original but BRAND NEW 998 Ducati Original radiator or the Febur...
Now, I also already purchase 1 unit of brand new electric fans so I plan to purchase another brand new electric fans (newer version do not have that dark yellow sealant protector that look like rust on top of the fan).
I mean the 2 OLD STOCK but BRAND NEW electric fans that came with this brand new radiator (with dark yellow sealant protector) might work just fine... but I am sure they are around 20 years old... so better buy another BRAND NEW set of electric fans just in case
Again those RUST looking top of this NOS electric fans is NOT rust, they are some kind of dark yellow sealant... but they do look ugly... and you can compare it to a brand new electric fan that I purchased and posted in the earlier post in this "BUILD" thread (some of the old timers in this forum will understand why I wrote "BUILD" with emphasize
Yep, that electric fans connector sure look's like the way it came out from the factory maybe 20 years ago... still BRAND NEW....
The inside of the pipe also looks like no coolant ever flow in there....
