February 24, 2022
youtube.com
Clean Ill wait for more info.Hi HKMP7,
just saw this picture on Instagram, could this be a solution for your brake/clutch reservoir?
Hi HKMP7,Fairings prep part 1
Now that the tank is done its time to get the fairings tackled. Adding some heat protection to the side fairings. The belly pan already comes with some from Ilmberger.
Added some stickers to the lower fairing.
All the Ducati race bikes have this decal on the belly pan. I guess to get some advertising even when they crash.
This decal is 340mm X 63mm
Yeah right this bike is savage it may throw me offThe only advertising I expect to see from your belly pan is on wheelie wednesdays
I'm using several types mostly machine sanding. The tight areas are done by hand.@HKMP7 Are you using a sanding block with the 2000 grit?
Thanks.Looks amazing !
interesting choice on the clutch cover !
I just tested my Ducabike clipon, it literally transformed the bike. The steer is so precise now! So much more room! Elbow dragging might be feasibe now….Updated Office
The office is nearing completion here are couple of new additions. Still deciding on which triple clamp kit but here are the controls.
Brembo Remote Adjuster
This part is not necessary but I love having it for convenience and it looks trick.
Replaced the bolts with Proti
CNC Racing left handlebar switch
Here is my custom switch for the left handlebar all black buttons and one red button just like on my start/stop switch.
I got the Pramac edition because I'm a fan of Zarco and Martin!
IMA clipons
