Last winter we all 4 got Arrow exhausts and two of these are broken already. One season, less than 5000km.
Perforated inner tube has torn, mine from left side, 4vs friend from right side. Tube is very thin titanium. We replaced it with thicker stainless tube.
Ebay seller didn't respond to us nor than Arrow.
Mine has something to do with db-killer, it's secured with big circlip which allow killer to rotate, killer has 30 degree bend, so if it rotates to wrong position, it can hit the wall of perforated tube.
But this is just bad quality.
Little force was needed to detach inner tube from outer cone, cos it was welded to outer cone.
It was pain to remove.
Then new stainless tube needed to tapered slightly.
And welded to end cap, so I can easily replace baffling afterwards.
New acousta-fill boa stuff that swells a bit, is easy to wrap around perforated tube.
And little polish to carbon parts, cos all my other carbon parts are glossy. Here lower is polished.
Closing with gas tight stainless rivets of course (not in the pic).
