I found a new "WALDO" the Ima handle barUpdate
So I was left alone for the weekend and decided to re arrange some furniture lol. Here is what we are working on over the winter break.
P.S. this took way too long to setup smh
No I'm running factory lower triples with the Melotti custom top clamp for now. I have a couple companies I'm considering tho IMA is one of them.Adrian, you running IMA triples too?
 . I wont bother with the ones on the tank since it will be painted. But the ones on the windscreen I'll remove and share in a future post.
	Sure. As you know I like subtle with details. So it will be the factory paint scheme with some exposed carbon accents. From 3 feet away it will look stock lol but up close you will see all the work.Hi HKMP7,
Will it be possible to share the color scheme that you plan on your new carbon fiber tank and carbon fiber wider fairings right now?
Or that is still a "surprise" "surprise" ?
	I can't wait to see the final resultSure. As you know I like subtle with details. So it will be the factory paint scheme with some exposed carbon accents. From 3 feet away it will look stock lol but up close you will see all the work.
All factory decals
	I want to wait to see if anyone comes up with full delete. So I can ditch the pump all together I believe its 2-2.5lb of weight that can be saved. If that doesn't happen I will go the plug the ports route.How proper a solution is a proper solution? Most guys just block off the ABS module with bolts and it causes no issues.
Full delete probably won't come until a true tuning solution is come up with, or you switch to a completely different electronics suite like Motec. However, in my travels I discovered the guy who did all the tuning and deconstruction of Kyle Wyman's MotoAmerica V4 the first year he raced, before he had the MM electronics suite from the factory. He apparently was able to dissect the ECU and develop a real tune. Was told he's a true wizard of the art of breaking modern ECUs (in a good way).I want to wait to see if anyone comes up with full delete. So I can ditch the pump all together I believe its 2-2.5lb of weight that can be saved. If that doesn't happen I will go the plug the ports route.
I heard something similar with a couple tuning outfits so I will wait. The feel with this setup is actually pretty good. I do notice with the added braking performance the ABS intervention happens a lot sooner.Full delete probably won't come until a true tuning solution is come up with, or you switch to a completely different electronics suite like Motec. However, in my travels I discovered the guy who did all the tuning and deconstruction of Kyle Wyman's MotoAmerica V4 the first year he raced, before he had the MM electronics suite from the factory. He apparently was able to dissect the ECU and develop a real tune. Was told he's a true wizard of the art of breaking modern ECUs (in a good way).
I'm waiting until I get more spare funds on hand before having a serious conversation with him, as I hate wasting people's time. But he might be able to work something out for you to eliminate ABS and/or some other things. Based out of Las Vegas I believe.
Name is Gary Dean at Speed Demon Motorcycles.
Keep us posted. When I tried to get hold of Gary regarding a former Grave’s R1 I was considering buying, he was not responsive.Full delete probably won't come until a true tuning solution is come up with, or you switch to a completely different electronics suite like Motec. However, in my travels I discovered the guy who did all the tuning and deconstruction of Kyle Wyman's MotoAmerica V4 the first year he raced, before he had the MM electronics suite from the factory. He apparently was able to dissect the ECU and develop a real tune. Was told he's a true wizard of the art of breaking modern ECUs (in a good way).
He took a few days to get back to me but ended up giving me his personal cell. It would be great if my stocks would stop dive dombing so I could actually warrant giving him a ring, lmao.Keep us posted. When I tried to get hold of Gary regarding a former Grave’s R1 I was considering buying, he was not responsive.
