Hi ggok,
That is a Technically good idea, however, to cover the brake line closer to the radiator, I need to take out the radiator and all the radiator bracket out again and since it is not that easy, I think I have to be satisfied with the current non protected setup
The line near the clutch housing is easier to be protected with the heat shield, but I want to be able to see the surface of the cerakoted solid cooper line just for the looks, so I will keep it exposed
Beside the stock flexible hose on the Superleggera is the STAINLESS STEEL Braided PTFE Hose so it transfer more heat, while my Goodridge Series 700 hose is ARAMID Fiber (Kevlar) braided PTFE hose, so the Aramid Fiber braiding should act as an extra head barrier compare to the stock stainless steel braiding.
Well, at least that is the theory
But of course, adding extra heat shielding like on the Superleggera pictures above will protect even better
