Ok, the AELLA frame slider was one of the very first item that I ordered for my bike almost 2 years ago.
In fact, I wasn't planning to modify my bike too much initially... just some AELLA frame slider to protect it... but I guess I got carried away (in a good way)
Now, due to all the steps, and all the mistakes in ordering the correct length of ProTi bolts... well it is not really a mistake, but I want to have the maximum length available for each bolts,...
the Right Side AELLA frame slider was never completely installed until today... yap... it had been test fit many times but only today, I finally finished it's installation PERFECTLY
Why... well here is why...
First, I need to replace the center bolt that hold the Rizoma mirror bracket that hold the Ducati by Rizoma rear brake reservoir with a ProTi bolts that have the correct maximum length for maximum thread engagement and the right head shape and as you can see below, I am replacing the ProTi bolts that I am holding in my finger with the ProTi bolt with larger diameter head and 5mm longer (total of 45mm length) that is already installed on the Rizoma mirror bracket:
So why this caused delay to installing the RIGHT side AELLA frame slider? well because the AELLA frame slider location BLOCK access to this Rizoma mirror bracket so I need to finish with this mirror bracket bolt first before I can install the RIGHT side AELLA frame slider permanently.
And after this, there are another 3 bolts that hold the full six/shiftech carbon fiber brake hose bracket, which also partly blocked by the AELLA Right Frame Slider, meaning I better replace these 3 bolts first.
These 3 Silver ProTi bolts were part of the kit from ProTi and they are TOO SHORT. So I replace them with a Gold ProTi with 2mm more length to 14mm:
And the result
Then finally, I can install the AELLA Right Frame Slider permanently. Now, due to the protrusion of the Rizoma Mirror Bracket that hold the Ducati by Rizoma brake reservoir,
I need to add SPACERS to the AELLA frame sliders to clear it, and here is the clearance after the spacers (pointed by my fingers)... I guess, I measured right down to the mm for the just the right clearance
And here are the spacers (note they are all STAINLESS Steel spacer because I like the finish better than an aluminum spacers):
Top right side spacer with
ProTi M6L70-OTB01 in Titanium Silver:
Top left side spacer with ProTi
M6L75-OT01 in Titanium Silver:
Lower Left Side spacer with ProTi
M6L45-OT02 in Titanium Silver:
Lower right side spacer
Here are the AELLA instruction manual, all the M6 bolts need to be torqued to 10Nm and the main center M8 bolts to 18Nm:
For the right side spacer, you will need to install the 2 top bolts first and tightened them to 10Nm.
Then, you need to position the center cylinder (of the slider) and tightened it to 18Nm.
Since the face of the slider cylinder have a very nice "AELLA" white color laser marking, I want to make it perfectly align horizontally when the bike both tires are on the ground.
So I asked my oldest son to hold the bike (without any stand) with both wheel on the ground, then I use rubber band so my left hand can have enough grip to hold the main slider cylinder while align the "AELLA" laser marking, with my right hand using a torque wrench to tightened it to 18Nm.
Here is the picture of the blue rubber band to help with grip:
and here is after centered:
by screwing this center bolt as much in as possible, it also self aligned the two lower bracket, and now you can tightened the two lower M6 bolts to 10Nm.
Next, you need to LOCK the center bolt with a lock nut and make sure you add a lot of Painter's tape to protect the surface in case your open ended wrench slipped (knock on carbon fiber errr wood)
Finally everything is finished and after a few dash of Honda Cleaner:
First notice how nice the AELLA "carve the dream" white laser marking at the end of the cylinder slider... that is why I want them to be align perfectly with both wheel on the ground
Then, how about that Gold Trim RING surrounding the main slider cylinder... it add a classy touch combined with the another AELLA laser marking and that "Ducati Performance" logo on the background
another angle:
From the front:
Yap, I think it is PERFECT, ... until I realize.. that there is one hole on the side of the slider cylinder, maybe for a screw driver to plug into to help align instead of my method of using rubber band...
and this hole on the right side is facing the front... which means if I ride the motorcycle, all the wind will bring dust into the center of the cylinder...
yap... after all the effort aligning above, I realize, I made a mistake,... so I corrected it my rotating the slider cylinder 180 degrees and make the hole facing backward of the bike like on the picture below,... and now I finally can say, IT's PERFECT
Pheew... so these are all the things that I am willing to do just for a PERFECT Right Front Slider Install...
Days are still young everyone so more updates later today....
