Ducati Panigale Bayliss 1st Championship 20th Anniversary - Project Build
Well done on having a go. I would replace the gaskets but unless specified by the factory workshop manual no need to renew nuts. From memory the torque on these is not high at all. Some bolts in critical components “stretch” slightly when fastened to torque spec. A good example is mounting assembly on front brakes of some cars to the front suspension struts. They are a one shot use.
Having done this job on my 1199 installing the full Ti system, get the factory torque specs for the nuts. If possible leave fairings off, short test ride and if all good on recheck then put the fairings back on. Akra normally supply some ceramic paste to apply to bolts so u can undo in future.
Koken Z series tools are great for these jobs as is ratcheting ring spanners. Good luck spannering👍
Good effort, save yourself a fair bit of $ doing it yourself + nice to know what’s going on under there. I’ve had mine on and off a couple of times, new gaskets each time & new nuts on 2nd change.
Dont forget to wipe your fingerprints off the titanium before you turn it on 😉
KODAKHODAK
Yeah cheers bro, I hear WD40 is definitely a good thing to use to wipe down before the first Intial start up.
Best place to get new gaskets and nuts from?
Wd40 does the job nicely.
I’d just get the part numbers and order from the dealer - I’m not sure if the akra comes with new ones in the box(?) but they’re cheap anyway.
KODAKHODAK
Well the final piece to this 2 year project has finally arrived, the Bayliss gets a pair of Matte Satin Carbon winglets from German supplier Ilmberger-Carbon I 💯 sure I am probably the first to sport these in Australia. Was very easy to install, they provide a drilling templet to match easy fairing, yup I drilled the fairings and didn’t regret it. Overall I am stoked on this project in memory of my father that passed away 2 years ago, definitely enjoyed making it my very own version. Enjoy the pics 🤟
View attachment 11956View attachment 11957
Nice to have memories of your Dad every time you look at the bike
Winglets look great
