Brooklynv4
I just saw the evap removal kit on their site I’m going to order it thanks.
Mine was made by Zircotec and I purchased it from Demon-Tweeks and here is the link: Zircotec Zircoflex 1 Gold Heat Shield MaterialFor those of you that put that gold foil under the tank and seat for the heat issues how has it worked and did you just buy a roll and cut it out I figure that would be the cheapest route. Saw a company called Pegasus that sells it by the roll fairly priced. Since I have the bike apart I figured it would be a good idea
What’s the difference between the zircotec and the teknofibra?Mine was made by Zircotec and I purchased it from Demon-Tweeks and here is the link: Zircotec Zircoflex 1 Gold Heat Shield Material
Hi Craig and BrooklynV4,What’s the difference between the zircotec and the teknofibra?
Hi BrooklynV4,Finished up the block off plates today I’ll probably do the evap stuff Sunday. I’m just going to plug the purge line. When I do take the air box off I only want to do it once so that’s when I’ll do coolant lines wrap it in heat shield etc
View attachment 6961View attachment 6962
No you only wrap the outside. That's the bottom of the airbox.Ok it looks like you wrapped the inside. Does it make a difference inside or out. Figure I’d do it since I’m going to have the air box off and waiting for parts from hsbk
