Something must be blocking the path of the fluid.Bought a pneumatic bleeder to get fluid in the system and I’ve had no luck
Questions:
a. Did you use any quick bleeder valve? (check to make sure it work)
b. Check the banjo bolts does not have any dirt in the small holes/pathways
c. Check the hose (and the banjos) does not have any blockage due to dirt going into it
d. Check the slave cylinder does not have any pathway block
e. Check the fluid reservoir and it's short rubber hose to the clutch MC does not have any blockage
f. Check the clutch MC for any sign of blockage on where it connect with the banjo/hose
g. Also disconnect the hose from the clutch MC, then fill the fluid reservoir and squezze the clutch lever. See if it squirt the fluid out. If it is then it should works fine.
In summary, both the clutch MC and slave are just hydraulic device with hoses to transfer the fluid.
