Brooklynv4
Sorry for the doubles of the pictures I don’t know how I wound up doing that
Hi BroklynV4,A little side view with the carbon sides cleared
Yes the carbon came as part of the kit but there are no markings that I can see as to who produced the carbon parts I also clear coated them myself they come raw in the kit. I had to also cut a small piece off also in the front where the two fairings come together as the hole for the screw that joins them in the front is to far undo I cut about 1/4 of an inch so they sit flush. Basically the hole is in the right place but the fairing needs to be inset where the clip goes for the screw to hold them togetherHi BroklynV4,
Very nice carbon fiber finish![]()
I assume the belly pan came from Termignoni. Is there any label behind it showing the company that produce this carbon fiber belly pan for Termignoni?
Also, did you clear coated your self or it came clear coated from Termignoni? Thanks
Hello BrooklynV4, I personally would routed through the stock holder as in your picture just because I like make it look as factory as possible.Quick question do you think I should leave the front brake line routed through the stock holder under the triple or leave it floating
Yes I am by passingthe abs that looks like a clean straight run I might switch it that way. Those triples look amazing by the way. The main reason I was thinking of changing the routing is to prevent any snags or pulling on the brake line. Thanks
I already have the lines I installed them. I left the stock routing for now because I just want to ride my bike when I get a chance I’m going to change it to bmwalpinas set up. I’ll take some pictures some time this week. Work got busy so I really don’t have the time to work on anything right nowDo you already have the lines? If you're doing an ABS delete, a more ideal way of routing the lines would be one from each caliper running up to the master cylinder. It's how they do it on race machines, makes bleeding much more simple (only have to bleed at the master as air travels up, no air trapped between the line between calipers) and reduces the chance of them getting caught on something. I plan on routing mine this way when I eventually bypass the ABS.
