Thyssenkrupp's weight spec from my previous weight in:
front: 2.9kg
rear: 2.6 kg
I'm going to try to locate a better scale so I can measure to grams
BST & Pirelli
Got a new set of the Supercorsa SPV3 mounted to the BST wheels.
Weights without tires
Front 2695g or 5.9lbs
Rear 2483g or 5.4lbs
I went to look at my friend's HP4R, their caliper for the bleeding, is very friendly, why ours is inside? brembo own us an explanation. :)
than brake lines routing would be another science project....because...how to heck to avoid the flow spinning rotation of the wheel....? :cautious:
Exactly right. I did see someone with that setup I tried finding the picture and couldn't.
V4SL radiator cap & Samco hoses
These hoses will add some style and hopefully reduce coolant temps. The SL rad cap is a billet piece of art!
SL cap
In my excitement I rushed to the garage to get these installed. No dice 🎲 🎲 one of the hoses was cut too short. Same issue @BMW Alpina had. Both of our kits must have been made on a Friday lol.
So I reached out to Samco and they confirmed my hose was too short. ”That’s what she said”. So they will be sending me a replacement.
To be continued:
Thanks so much @HKMP7 for contacting Samco UK and also helping me to learn the process on how to get replacement for my too short Samco hose with the correct length. (y)😃
