Awesome bike
HK has a sworn enemy??
ThanksAwesome bike
BST & Pirelli
Got a new set of the Supercorsa SPV3 mounted to the BST wheels.
Weights without tires
Front 2695g or 5.9lbs
Rear 2483g or 5.4lbs
They actually can be flipped. So If you want the bleeder outside you can.I went to look at my friend's HP4R, their caliper for the bleeding, is very friendly, why ours is inside? brembo own us an explanation.
than brake lines routing would be another science project....because...how to heck to avoid the flow spinning rotation of the wheel....?They actually can be flipped. So If you want the bleeder outside you can.
Exactly right. I did see someone with that setup I tried finding the picture and couldn't.than brake lines routing would be another science project....because...how to heck to avoid the flow spinning rotation of the wheel....?
V4SL sidestand
This helps me eliminate more silver.
I ordered:
Sidestand part #55621141AB
Pin part #82113731AA
Then added my burnt Ti Aella sidestand assist.
Its the same weight as the factory sidestand. Just matches the theme much better.how much weight saved? looks nice to match your bike fosho!!
The pin goes on the inside of the kickstand it holds the return spring assembly.Nice. Why order the pin and then use the Aella?
That is a VERY HANDSOME SetupMotocorse side frame plate plugs
These finish off the side plates
Replaced the bolts with Proti
V4SL sidestand and Motocorse
