BST & Pirelli
Got a new set of the Supercorsa SPV3 mounted to the BST wheels.
Weights without tires
Front 2695g or 5.9lbs
Rear 2483g or 5.4lbs
Gorgeous 😘
Also interesting that the much smaller front wheel actually weight more than the larger rear wheel, must be due to the weight of the center hub/bearing assy on the front wheel.
Another testament of how much light carbon fiber part is !!! Congratulations @HKMP7 😃
Gorgeous 😘
Yeah both of them feel like feathers lol. I'm not sure if the wheel weights are for balancing or holding them on the ground. :ROFLMAO:
Corsagarage Titanium overflow cap
This cap is slightly heavier than the stock plastic one but it looks awesome so I don't care.
I just stumbled upon these caps this week and absolutely love them. Great piece. Alot of the ones for the hyper are just covers that you put over the OEM plastic cap where this one is actually the cap and threaded. Fantastic part!
By the way, as you guys might notice, there are MANY "GUESTS" to this forums who have not register as member yet, but "lurking" and reading posts in our forum. 😉
I bet, Corsa Garage would suddenly sell SEVERAL of this Titanium Radiator Reservoir Caps to those "STEALTHY" Readers maybe even including The notorious "DOC" 🤪
Note: to all the "STEALTHY" Readers out there, please don't hesitate, don't be shy, and register to become member of this forum.
We promise, it will be the most comfortable, informative, and most importantly CIVILIZED Ducati Forum in The World 😉
Fren Tubo carbon lines installed
I love the way these turned out. The routing is same as stock. The kit has everything needed to make a simple install. I used Motul RBF660 to fill the system.
Weights and measures
Stock lines and 9 banjos 731g
Fren Tubo lines and 9 banjos 314g
That's a 417g weight savings!
P.S. I could have saved a couple more grams but I used 5 Ti banjos and 4 alloy banjos. I used the Ti ones on the visible banjos.
Fullsix subframe install
After removing the bodywork and tank its a pretty straight forward job. Just take note of how the wiring is routed.
The subframe loosely attached
Wires tidied up and I added some heat shielding to the fuel pump loom.
Installed
Bruce Wayne
Installed
Did you modify the fuel line or leave std? Its a really crap design
