On the V2, when you remove the passenger seat there is a grab strap that is mounted with two fasteners from the top. SInce I’m not carrying any passengers, this was a starting point for the stand offs that I needed to make to mount the new tail light bracket from underneath.
Thanks to my buddy Enzo at work, yes thats his name! Perfect man for the job right??
He machined me these aluminum stand offs that pick up the fastener holes from the bottom.
6000 series aluminum to keep the weight down and the strength up. These posts are installed once and never removed so the aluminum was the perfect material.
The mounting bracket had to be steel because this is where the taillight bracket would be going on and off to remove and replace the license plate between track days.
Top view of the subframe. The aluminum standoffs fully torqued.
This is key. Steel roll pins attach the tail light bracket to the stand offs. This provides a secure mount and also makes it impossible for the posts to come loose!
