hey whats up, thank you!Beautiful bike Lucati!
eoukd it be possible to share what fan you got abs how you installed it when you removed the original fan and shroud
I have a track only 899 and want to clean things up there. Did you solder the stock conector to the new fan ? I si ser if u can run the bike without a fan at all
Off the top of my head, its a SPAL 5" low profile fan (pull direction). yes, i did solder the oem connecter to the new fan. I originally made a mount that copied the bolt holes of the OEM shroud, but since i put in the FM exhaust that took the same space, I had to move the fan a bit lower. I did this by bolting one of the mount points ( lowest, at the bottom of radiator) and just used zip ties through the other mounting holes on the fan, through the radiator.
i do believe you can run the bike without a fan if its track only, since you arent sitting in traffic at lights and such. when i bought the FM exhaust, i was told i needed to remove the fan because its for race application only, but i use my bike on the street as well, so i needed the fan
