Hi, Lucati,Can I get your guys opinion on this, sorry my writing is pretty bad in the pictures haha. On my thumb brake, the fluid is in a reservoir connected to my left clip on, taking up space. This is how the diagram says to set it up with the thumb brake. But does the fluid have to be there? I can’t think of a reason it HAS to be at that point. I was thinking of getting a new master cylinder with the reservoir integrated into it. So I made some diagrams to make it more clear (hopefully)
Current set up...
possible set up..
If you don't want a permanent reservoir at your thumb brake, perhaps use a rubber hose as a small reservoir. You will need a real reservoir connected to this rubber hose when you fill the fluid and bleed the thumb MC, and later after you bleed it, take out the reservoir and just plug this rubber hose. This small rubber hose will act as mini reservoir for your thumb brake.
