The strangest thing happened... but most likely due to lighting...
So when I took out the bolt that hold the 2 halves of the caliper (which is on the opposite side of the mounting bolt), the Light Gold Color actually looks better !!!, and I think the only logical explanation was I did not use a flash light and only use room lighting on this latest pictures. So now, Light Gold ProTi bolts is the winner
I measured the bolts and they are M8x40mm with 13mm head diameter, and I will choose this part# ProTi Bolts M8L40-OTB01 in Light Gold Color x 2 pieces that hold the 2 halves of the Brembo Caliper (picture below)
But you can also choose this alternative Part# M8L40-OTB04 if you prefer it to looks like the original Brembo bolt:
For the Caliper Brake Pad Pins, I choose this one: ProTi B-PIN-P01 Brake Pad Pins for Brembo REAR Billet Caliper in Light Gold Color x 1 pieces
But you can also use this alternative Part#B-PIN-02, picture below:
