The ChaseBay F shape distribution block and the rest of the Goodridge Shadow Line Banjo Adapters arrived.
The ChaseBay F shape distribution block is VERY compact and perfect to be place on the original location above the radiator.
It also came with 2 Female Tube Nuts and the inserts in case you want to plumb a hardline tubing to it.
Both pictures shows the size in both cm (metric) and inches to illustrate how compact it is:
This is the location where I will make some kind of bracket to hold it just above the radiator (like the plastic bracket that hold the original steel hardline):
Here are the rest of the goodridge banjo adapters:
And now, please pay attention to their location on the ABS module:
I started measuring the Goodridge Flexible 700 Series Aramid Hose using a flexible measuring tape so I can fully follow the plan "contour" of the hose:
about half an hour later, I already have the measurements of all the flexible braided line and ready to order it. Once they arrive, then I can "Adjust" the hardline measurement by cutting the hardline (and bending it) myself.
Of course you can also just copy the length from the original Ducati brake line, but I want to modify it so it will have more sections using hardline and as less as possible of flexible line because the flexible line, no matter how good they are will have more "expansion effect" under full pressure thus giving less firm feeling, especially since our bike have a LONG LONG line back and forth to the ABS.
The bill of material (BOM) for the Goodridge 700 series Aramid braided lines and using all Goodridge Stainless Steel fitting:
(the latest letter on the part#: C means Stainless Steel, while CBK means Stainless Steel Black Shadow line)
End Fitting A : Part# S6090-03C, 90 degree Forged Female Concave Seat Stainless Steel
700 Series Hose : 8cm (centimeters)
End Fitting B : Part# S451-31C, Female Metric Concave Swivel Stainless Steel
End Fitting A : Part# S5070-03
CBK, 70 degree Banjo with Extended Neck Stainless Steel
BLACK color
700 Series Hose : 14cm (centimeters)
- Hose#3: ABS to Rear Caliper
700 Series Hose : 10cm (centimeters)
End Fitting A : Part# S451-31C, Female Metric Concave Swivel Stainless Steel
700 Series Hose : 16cm (centimeters)
- Hose#5: To Staubli of Rear Caliper
700 Series Hose : 15cm (centimeters)
End Fitting B : Part# S6001-03
CBK, Straight Female Concave Seat -AN3 Stainless Steel
BLACK color
End Fitting A : Part# S6001-03C, Straight Female Concave Seat -AN3 Stainless Steel
700 Series Hose : 21cm (centimeters)
End Fitting B : Part# S5094-03
CBK ,45 degree Banjo with extended neck Stainless Steel
BLACK color
- Hose#8: ABS to "F" Distribution Block
End Fitting A : Part# S6045-03C, 45 degree Forged Female Concave -AN3 Connector Stainless Steel
BLACK color
700 Series Hose : 88cm (centimeters)
Line Locator : 2 (TWO) RUBBER mounting Grommet along the hose
CBK, 45 degree Banjo Extended Neck Stainless Steel
BLACK color
The only 2 lines that I had not included in the bill of material above are the 2 final lines from the ChaseBay "F" connector to the front left and right caliper,
because I want to bolted the ChaseBay "F" connector with a bracket first before I measure the ideal length of the hose that will goes to the Left and Right Staubli Quick Dry connector and then to the Front Calipers.
However, I already know the end fitting of both which will be
45 degree Forged Female Concave -AN3 Connector S6045-03C with 1 rubber grommet on each hose and ended with Straight Female Concave Seat -AN3 S6001-03CBK that will connect to the Staubli.
Ok, now all I need to do is get a quote from Goodridge because all the connections above are secured using Crimping style and I don't want to spent a few thousand dollars to purchase crimping machine
I could build all the hose above myself, but then I got to use the 600 series regular stainless steel braided use and use the "reusable" crimping end fitting. Since for this build I am determined to use the 700 series Aramid Fiber hose which only accept crimping to secure it to their fitting, so I got to pay Goodridge to build all the hoses above for me.
I also need to place an order for the Cooper Nickel hard tubing (which is cheap), but all the tooling needed,
It will cost me about $1,000 for the cooper nickel hard tubing and all the tooling (Earl's flared tooling alone is already almost $500).
I want to buy the best and most versatile tooling so I can use it for future brake line projects (not that I plan to do any right now)
oh, last, I found that the most flexible banjo shape to use for the RCS Corsa Corta master cylinder would be a 45 degree banjo, which I found by simulation using the 45 degree Goodridge Banjo adapter that I have (ignore the Stalhbus banjo bleeder in this picture, I just use it to secure the 45 degree banjo when I was doing the simulation):
