Rizoma handle bar grip with CNC Racing ZERO SLACK throttle bar (like the Throttle Spacer but without that spacer)
However, (I found this later in the future after the parts below arrived), if you want to use the same Rizoma handle bar grip, turn out it already came integrated with the Throttle Bar, so the CNC Racing Throttle bar will not be needed.
But since the Rizoma handle bar grip use the same "slack" design like stock, you will need to use that "throttle spacer" to remove the slack.
Ducati Performance Rear MudGuard/Hugger (I sold the original carbon unit that came with my bike so I can have this one with the "Ducati Performance" Label on it).
Cannot let HKMP7 rocking "Ducati Performance Label" on his rear mudguard alone
Ducati Performance Carbon Generator Cover:
Ducati by Rizoma Front Axle Slider (which I temporarily install right away)
Unfortunately 16RCS CORSA CORTA Clutch Master Cylinder was delayed until Fall/Winter 2020, now ETA in October 2020
