I am test fitting my stock Ducati by Rizoma rearsets to see the space and fitment and right away I found out that I need to remove a small bracket that was part of the holding mechanism for the stock exhaust manifold heat shield (rear), left picture show the position and right picture show after I remove it:
But now, the lower part of the rearset where the rear brake light sensor is mounted is the section of the rearset that is hitting the SC-Project WSBK carbon fiber exhaust heatshield:
So, the only way to clear this is to add spacer to move the rearset outward:
And even with the black spacer above (about 10mm spacer) it is still way too close and any movement of the exhaust pipe will most likely scratch the SC-Project WSBK Carbon Fiber Exhaust HeatShield, so I decided to add a 3/4" black spacer:
Which now gave good clearance (although now I think there is too much clearance so I might try to find a spacer that is around 12mm to 15mm max, and here is the clearance that I know have with the 3/4" spacer:
This is how it look like from the side, so it is still looks good:
However the BIGGEST issue here is that most likely the upcoming Motocorse Rear Sets will NOT fit because the Motocorse design does not allow for outward adjustment like the Ducati by Rizoma, and if you notice from the picture below, the bracket that hold the rear master cylinder is located further inside and there is no way it is going to clear the SC-Project WSBK Carbon Fiber Exhaust Heat Shield.
I could make a hole on the Carbon Fiber HeatShield, but then the heat from the exhaust pipe will leak to the rear set and most likely will DISCOLOR the anodized surface quickly and make the rear set ugly so I don't want to do this... Well too bad, there goes my plan to use the Motocorse rear sets in matching Gold Anodized Color then.
Oh, I actually thought that I might somehow install the whole exhaust piping incorrectly, meaning too far to the right so I check the spacing between the exhaust pipe and the swing arm, and I found out that there is already barely any space available between them,
so there is no way I can move the exhaust piping further left/inside to get more clearance for the carbon fiber cover. Picture below is the spacing between the exhaust pipe and the swing arm:
