Ok, so this is a HOT Sunday here in Silicon Valley, and no more appropriate project than heat shielding project
First, I used the original Ducati heat shield as a template, then I had to modify it a bit because the original plastic belly pan from Ducati have slightly different shape/size holes then the Peter Lieb Carbon Fiber Belly Pan:
Another use of the original Ducati Heat Shield as template on the Zircotec Zircoflex Gold Heat Shield:
This is Before and After for the right side belly pan:
And this is for the left side belly pan (no before picture, just after), and I am pretty sure it is well protected
Next, heat shield the Ilmberger Carbon Fiber Side Fairing Vents, on which I am using the Original Ducati heatshielding (with the black carpet surface) just like the original.
However, the original plastic Ducati side fairing vents have some plastic stud to lock this heatshields, but the Ilmberger Carbon Fiber version does not have it, so I have to add EPOXY as adhesive, and I am pretty sure it will stay and hold it for a very long time
Left side, Ilmberger without any heatshielding, right side original factory plastic vents panel with a lot of heat shielding:
Next, the Ducati heatshielding does have some double tapes but of course not enough so I add the Epoxy:
Then I applied it and hold it with 3M painters tape until the Epoxy dried:
By the way,
the original plastic panel also come with one clip to hold the wiring, so I purchase that clip and attached it to the Ilmberger Carbon Fiber Side Vents panel:
The original plastic panel also came with some clear plastic film protector (like a clear bra material):
So I install it too:
That is what I did this Sunday, (while watching TV with my family), so it is a relaxing weeekend...
Now, I need more ProTi bolts to arrived before I can continue so hopefully they will arrive this week and just in time for next weekend, but if not, then progress will be delayed a bit...
