1st of all i want to congratulate everyone that post in this site. Everything that i read was so helpful to understand some things.
After this said , and taking consideration that i am not a tuner or and technician i would like someone to simplify some things for me.
1. I have a V4 2020 and i bought a used full Akrapovic exhuast system but without the Up Map from Ducati. I want to know if its possibly to go to a dealer and install the Ducati Up Map for full Akrapovic exhaust.
2. Is is possible to custom flash my ecu or i have to stick to official akrapovic map or a map from brentuning, SLR etc.
3. My bike will be used as a track bike so the DTC EVO 2 i think its crucial for me especially for the refine on the DQS (after last track test i think DQS is very slow and oriented to road use.). So i want to know if there is any other way to install EVO 2 besides going to a dealer.
4. Does the upgrade to EVO 2 (official or not ) will affect my ECU map ??
Hello Kneedrager,
I want to add that for the first question, when you purchase an Akrapovic exhaust, the Ducati dealer that sell that Akrapovic exhaust need to register your exhaust serial number into the database at Ducati factory and married to your VIN number. Even if you buy from a non Ducati dealer such as WRS.it (where I bought mine from), the Ducati dealer that sell the exhaust to WRS.it is the dealer that register your exhaust to your VIN (not WRS) because only Ducati dealer can register to Ducati factory server through their diagnostic system online.
So, since you buy it used, there are 2 possibilities. If the original owner never ask the Ducati dealer to register that exhaust then you can just register it to your VIN. (You will need to know the serial number on the original box of the exhaust).
But if the original owner already register that exhaust to his VIN number, then you cannot get the Ducati official map anymore... unless somehow, you can persuade Ducati to remove the previous registration (I am sure this is doable, but will Ducati do it for you is another question that I believe most likely no). But if you can remove the previous registration (divorce it from the previous VIN), then of course you can married this used exhaust serial number to your bike VIN.
So, for you the simplest/easiest way is to just get an after market map from SLR/Brentuning/Rexxer etc.
From what I remember the DTC EVO 2 will overwrite some part of your ECU map,
Also, there is a sequence that your Ducati dealer need to follow and I copy and paste the old email I sent to my Ducati dealer (because I just want to make sure
![ROFL :ROFLMAO: :ROFLMAO:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And here are the steps:
- FIRST step is to Upload the Akrapovic ECU UpMap (FIRST).
Also please note that there are 2 different Akrapovic UpMaps.
The lower performance Slip-On Akrapovic and the Higher Performance Full System Akrapovic, so please kindly make sure your mechanic upload the correct Higher Performance FULL SYSTEM Akrapovic Up-Map.
- Only AFTER the Full System Akrapovic UpMap had been uploaded to the ECU, then your mechanic can upload the DTC EVO2 software as the SECOND step.
The reason is because there are 2 different versions of DTC EVO2.
First version (code# 58) of DTC EVO2 is to be used with stock exhaust/stock ECU map
While Second version of DTC EVO2 (code# 67) is to be used with the Akrapovic exhaust/Up-Map.
If your mechanic uploaded the DTC EVO2 before uploading the Akrapovic ECU UpMap, then the DTC EVO2 uploaded will be the lower performance (Code#58) for the stock exhaust because your DDS will not detect the presence of the Akrapovic UpMap in the ECU.
That is why the Akrapovic UpMap need to be uploaded first to make sure your DDS detect and then upload the higher performance DTC EVO2 (Code#67) for Akrapovic UpMap.
I found the table below from Ducati Service Repair Bulletin SRV-SRB-19-032 related to DTC EVO2 which summarized it quite well:
