Ducati 998s FE Final Edition (REPLICA but MODIFIED FAR BEYOND the Original) Build Thread
I started installing the DLC-Coated Titanium Piston one by one while taking the stock aluminum piston one by one. I used Motul Brake Fluid to "lubricate" the seals while inserting the new DLC-Coated Titanium Pistons:
Then reinstall the brake pads:
And the upgrade was successfully completed :cool:
By the way,
I wish the Motocorse spacer that came with the lower fork bracket kit can fit, but they do not... so a few weeks ago, the Correct Spacer for the GP4-MS caliper finally arrived. It is a Red Anodized spacer at 12.5mm from Addiction Motorsports in UK.
And now the position of the brake caliper against the edge of the T-Drive Brembo rotors are perfect:
But I found out, we still have issues. The Right side T-Drive rotor is not fully centered, and they're almost rubbing on the caliper surface. This is not acceptable, so I re-measure the rotor spacer thickness again.
I then discovered that Alpha Racing in Germany offers a high-quality rotor spacer with the correct bolt hole pattern and the right thickness, so I ordered it, and it arrived extremely quickly. I ordered 2 thicknesses, the 1mm and 0.5mm, so that I can stack and swap if needed:
I need to take out the right T-Drive rotor to install the new spacer, but since I already balanced this wheel, I use a Red Sharpie to create dot-markers on the position of the T-Drive rotor so I don't need to re-balance the wheel again.
I measured the custom CNC machined spacer that I made a long time ago, and the thickness is 2.42mm:
I decided to stack 2 x 1mm of Alpha Racing spacers for a combined thickness of 2mm to replace the 2.42mm spacer above:
Then I install the right T-Drive rotor back to the wheel:
And now they are centered without getting too close to rub the caliper:
Next, I will be posting about installing the Goodridge 700 Series Aramid Fiber (Kevlar) brake line soon.
Found some bargain on eBay UK, submitted an offer, and got lucky, so why not for some NOS Ducati Performance bike cover:
Then, more Goodridge fitting needed to complete the brake and clutch lines arrived directly from Goodridge in UK:
I need this banjo fitting for the first line to the front brake master cylinder:
I need this fitting for the second line going to the front brake lever:
They will be mounted on top of each other (STACKED) like in this picture:
Then this banjo fitting for the clutch slave cylinder:
Then this fitting for the clutch master cylinder:
These 2 adapters are for the rear brake master cylinder:
I did use the original Ducati line for some reference, but mostly it is not really valid for my application:
I am using this Earl's annotuff aluminum fitting for the rear brake, but I just don't like it, so I am going to replace it with a stainless steel version:
This was how I plan to reroute the rear brake line through the swingarm (hold by the carbon fiber chainguard):
This is how I was rerouting the clutch line from the slave to the clutch master. Notice, I need to use a dual nipple to combine 2 shorter line for the clutch because all of these Goodridge 700 series Aramid Fiber Reinforced lines were extra lines that Goodridge UK made for me, but have mistakes on their fittings, so I have them for free.
I feel bad throwing them away because they were brand new (and still brand new) and its an expensive line. So I just need to be creative with some adaptors.
Having said that, I don't like the way the clutch line double nipple located on the frame so I decided to re-measured and found out, the lines going to the rear brake are better to be used for clutch line, while the clutch line can be used for the rear brake line so I swapped them.
More about it soon.
Next, well actually this is many months ago (I just forgot to post it), a PAIR of Custom CNC machine Titanium Injection Holder arrives:
I also found a pair of Titanium adapters to AN6 for the fuel line to be attached. This Titanium Adapter (with heatsinks) normally used for part of Turbo system:
I attached the AN6 adapter to the Titanium Injector Holder:
Here is how the injector being hold by the Titanium Injector Holder:
This is how it likes mounted with ProTi Titanium bolt to the CNC machined velocity stack from JetPrime:
I still have the original Fuel Pump assy. From my 998, and initially, I thought of selling it, but then I thought about it, I decided to just build a SECOND set of fuel pump as a spare.
I will of course make this second fuel pump assy. looks as good as new set. First thing is to start collecting all the parts for the fuel pump assy. that Ducati no longer produces, and below is one of those parts that arrived:
This is also a few months ago, but I forgot to post, when I purchase all the Stahlbus quick brake bleeder valve and install it on the brake calipers and master/slave cylinders:
I also swapped the Goodridge 700 hoses for the clutch line, from the one originally for the rear brake line, so now it fits better for the clutch. It is now the longer 1 piece while the rear brake line is 2 pieces joined together:
But it is still about 1cm to 2cm too short, so I found a solution that I will post later.
I also need to have hose management for the front brake hoses and I decided to replace the past fork hose clamp of Ducati 999 to the clamps from 1198 (picture below show before and after), the 1198 clamp is a close loop design, more secure:
The only issue is, its diameter is too large for the location I want to be on the Ohlins forks, so I will need to add some type of spacer (which I also already have the solution and will show later).
Now, it's time to bleed the clutch brake line.
Install the Goodridge clutch line with a Goodridge swivel adapter from Metric to AN, then to the banjo. Yes, I need this adapter because, as I pointed out, these Goodridge 700 series Aramid Fiber reinforced hoses came from Goodridge with the wrong end fitting. But rather than throw them away (well, they are custom-made length and brand new), I decided to just add an adapter.
Besides, they look more "technical" with these adapters... :p
This is how I routed the clutch line:
If you recall, this clutch line was still about 1 cm too short, so to overcome this, I replaced the banjo on the clutch slave cylinder with a slightly longer banjo, which solve the issue:
Yes, it is perfect now:
I chose Motul RBF660 for the fluid. Initially, I want to use the Motul RBF700 but I read somewhere in the spec that the RBF700 is not mixeable or might have issue if mixed with a DOT 4 or even an RBF660).
Since in my Panigale V4 916 25 Anniversario, I already used RBF660, I decided to just stay with RBF660.
I used my trusted Vacuum brake bleeder combined with Stahlbus quick bleeder valve:
and DONE:
A bit of intermezzo...
I want to see which rear view mirror color I should choose, so I need to install the front fairing temporarily to do that...
Ok, back a bit... I actually already have the original RED color 998 plastic rear view mirror. I also have the brand new old stock still sealed in the box, Ducati Performance Aluminum Silver rear view mirror, plus I have a Rizoma Veloce L Sport (with turn signal) also ready for 998.
But... I still prefer a Rizoma Stealth, problem is Rizoma will NOT make one for 998 for obvious reason... but this is DucatiMODIFIED we are talking about... so... I have some idea :cool:
But first color...
Ok, here are the quick test fit, and I suddenly feel warm in my heart... finally I see how it looks with the front fairing... all this effort, all this years are worth it 😌
Then I want to see how it look with it's younger brother,.. and yeah,... I know I made it 😌:
Ok, back to business.... test fit how it looks like with a Rizoma Stealth in Black Color, and yeah... I think I want it this way 😉
Note: of course, I can easily cheat by buying the copy cat (fake) Rizoma which have elongated holes to accommodate different mounting hole spacing, but then it is cheating... so the only way is to modify an original Rizoma Stealth Mirror from another bike model that Rizoma Italy made... so stay tuned... as I said, Ideas has been floating around...
Going back a few weeks again,
Start with the dual Banjo bolt from ProTi with Ducati's original cooper washer:
Adjust the position of the front brake fluid reservoir, make sure it will clear the front fairing (and front fairing holder):
Everything looks ready, all bolts tightened to torque spec (notice the orientation of the 2 front brake line banjos):
For front brakes, I make sure I use the recent production Motul RBF660 (I have some older but new unopened bottles that I will use for flushing the line, but for the front brake, I need to make sure I have fresh fluid):
Bleed manually:
But took too long, so use my Vacuum brake bleeder:
Then bleed the front master cylinder, to make sure no air bubble:
Cap the Ducati by Rizoma brake fluid reservoir, and now it's a perfect firm brake lever:
Now is the time to center the axle, first making sure, no leak and all line/speedometer cable routed properly:
Put a lot of Gadus Grease B on the Motocorse Titanium Brake Caliper bolts:
Tightened the brake caliper bolts lightly
Pull the brake lever then tightened all the brake caliper bolt to torque:
Apply Gadus Grease B on the lower fork axle ProTi Titanium pinch bolts:
Tightened the right side pinch bolt (only) to torque:
Put Gadus Grease B on the AELLA Titanium Front Axle Nut, and tighten it lightly:
Press the fork up and down:
Tightened the axle nut, then tightened the left lower fork pinch bolt to torque:
Clean all the extra grease:
Right side too, need to be cleaned from all those grease:
Now, the finishing touch, the Ducati by Rizoma front slider. Note, this looks like the Panigale V4S front axle slider, but in fact it is not. It need to be a bit shorter so... I forget what other model it came from, but I believe it is from Hypermotard (I bought this shorter one a few years ago):
Install the front axle slider:
Next, organize the routing of the front brake lines and the speedometer cable. The 1198 fork clamp I bought is perfect but it is not as simple to tightened, so I decided to Epoxy the ProTi Titanium Nut, this way I can just screw in the bolt easily without worry the nut can fall, slanted or spin and eat the plastic clamp:
To make sure the epoxy does not accumulate and block the thread, I use Loctite Anti-Seize and insert the ProTi Titanium Bolt right away:
Then, after the epoxy dried, I installed the fork clamp on my fork:
I also added one more clamp higher on the fork to hold the front brake lines near the front master cylinder:
Having said that, the 1198 clamp is very slightly loose, so I added a lining of foam tape:
Now they are super snug, and tight:
Same thing with the top clamp, also add the foam lining:
More updates:
This Stainless Steel bolt for the hose clamp is "ok" but not up to level of "sophistication" as the other bolts and I found a perfect replacement from ProBolt UK :cool:
So now it is Titanium by ProBolt UK. The only thing is, the ProBolt UK Titanium bolt does not have Phillips screwdriver capabilities, so make sure if you are replacing them, you have access to tighten with a regular socket tool:
The look around to find more hose clamp that can have their bolts replaced with the Titanium Bolts from ProBolt UK:
I then reinstall the Ilmberger Carbon Fiber Timing Belt Cover for the horizontal cylinder that was taken off to prevent scratching while installing the wiring harness and Goodridge Oil Line for the Cylinder Heads:
A few posts above (and almost 2 weeks ago), I used the first version of Rizoma Stealth Mirror for First Generation (2018 to 2024) Panigale V4S to imagine what it would look like on my 998, and immediately, I want it that way.
So, I decided to buy one of the first batch of Rizoma Stealth Mirrors for the 2025 Ducati Panigale V4S that arrived on our shores.
But after I buy it... I began to worry, because there is a chance the Rizoma Stealth Mirror for the latest YEAR 2025 Ducati Panigale V4S, cannot be modified to fit my 998.
So when the Rizoma Stealth Mirror arrived yesterday, I opened it immediately to see how it mounts to its lower bracket (it is a 2-piece design).
Anyway, let's start with the pictures... because pictures speak a thousand words :cool::
OK, so we confirm they are GORGEOUS ... but can they be modified to fit my 998?
Let's start by taking out that RED warning Sticker saying do NOT UNSCREW the bolts:
VOILA the hidden M8 Hex Socket Screw, what a pleasant sight... because this means EVERYTHING will be just FINE 😌
This morning, I start by taking out that "DO NOT UNSCREW" Red Sticker completely:
Heat up the area where the small Set Screw with a heat gun to loosen it up. That Set Screw LOCKS the main M8 screw in place:
Oh, also that set screw actually need a very small IMPERIAL size Hex Socket tool to open. Once I took out the small set screw, I use a large socket wrench to took out the main M8 screw:
But despite heating up more with heat gun, the M8 screw will not open, so I get my Makita Impact Driver, set it up at Medium Impact Power and start opening it...
After several hard tries, it finally open:
I then do the same to the SECOND mirror, but this second mirror main M8 bolt just won't open. Either the Loctite on this second mirror grips stronger, or the set screw, damage the thread on the M8 bolt making it cannot open...
At one point, I even began to think this M8 might be a left hand thread version... but after carefully viewing the thread (through the small set screw hole with magnifying glasss), I am quite sure they are the regular right hand threaded.
So I keep heating it up with my Makita heat gun, then spray a lot of Kroil lubricant for loosening up seized threads:
Finally, after cranking up the power level of my Makita impact driver, I am able to took out the M8 main bolt for this second mirror:
I quickly wash the mirror with water then wipe with alcohol, inspect the thread and everything is good... what a relieve since any damage is costly (they are $699 a pair):
I also found an extra ProTi M8L35 (35mm length) bolt that I will use to mount them to the 998 mirror center hole stand mount:
But I still need to align and drill the holes on my MS Production Carbon Fiber front fairing/cowling, so I cannot mount it now. I also will add an adapter below the mirror mount so it will confirm with the curve contour of the front fairing/cowling edge.
In the meantime, I took picture of how it look (roughly) when mounted to the 998... and Yes, I think I made the right choice 😍
A few more Staubli Dry Break Quick Disconnects and Goodridge heat-resistant sleeving just arrived from Pegasus Auto Racing Supplies
Pegasus Auto Racing, most of the time, has all this RARE Staubli in stock, and their price is normally the lowest too. It only took about 1 week for the order to arrive from Pegasus Auto Racing office in Wisconsin to my home in California.
The Staubli SPT08 will be used for DryBreak inside the airbox (similar to the way the Ducati factory "plastic" quick disconnect works for the injector hose inside the airbox, but of course with much higher quality Staubli instead.
The Staubli RMI12 10AN Dry Break QuickDisconnecs on the other hand will be used for the hose between the crankcase oil breather and the airbox, allowing to remove the airbox easier (insted of prying the silicone hose out from the reed valve).
Next (although this was done a few weeks ago):
I installed my Fumoto Oil Drain Valve, but it just stick too low to the ground, reducing already low ground clearance of the deep sump:
So I decided to replace it with Stahlbus quick disconnect oil drain valve:
Yes, I bought several different cap color so I can select which color I like more:
Open the package so I can inspect further:
Compare the 2 caps:
Turn out, they (the 2 caps) not only differ in color but also in shape and height.
Next I cleaned the thread again:
I add antiseize to the thread and also oil to the cooper gasket:
Also oil on the surface of the deep sump that will came in contact with the cooper gasket:
Set Torque wrench to 20Nm:
Install and tightened:
VOILA, much better with ground clearance:
I decided to tightened it once more to 21Nm:
Take out the Motocorse Titanium Oil Filler Cap:
Start filling up the engine with Motul 300V oil (remember, that Stahlbus oil drain valve I just installed is a valve that normally off position, until I insert the mating drain valve, that is why I can just fill the engine with putting on the cap):
Full for now, will check again once I turn on the engine in the next few weeks:
Check, make sure no oil is leaking:
I decided to use the standard silver cap that originally came with the kit because it provides more ground clearance comso-calledpare to the black (so called racing cap version from Stahlbus):
Then tightened the Motocorse Titanium Oil Filler Cap to 5Nm, and done for oil filling for now:
Again, another progress from a few weeks ago:
Bought more AntiFreeze Coolant in preparation to fill the radiator:
The ProTi Titanium Nuts for the plastic bracket to hold the fuel filter arrived, and I install with Loctite:
The bolt also ProTi Titanium:
Also bought some ProTi SELF-TAPPING Titanium Screws along with some Titanium Spacers to space it out (since it is a bit longer than the original steel screws), these to hold another filtering system inside the fuel pump assembly:
A second set of ProTi Titanium Bolts for the Fuse Box (for the new wire harness) (I already bought the first set for the old wire harness and don't feel like taking it out again, so I just bought a second set):
Here is the nice AFAM front sprocket, but it is not nice enough:
Enter the Gandini POLISH front sprocket that I bought from MotoCorse JAPAN:
Side by side comparison:
Yes, Gandini is nicer so it goes on to the bike:
But I am annoyed by that center threaded hole so found some super thin head ProTi bolt (ex disk brake) that I no longer use:
Apply fresh coat of Loctite 243 Medium:
Install on the center hole:
Torqued it to 35Nm:
Looks so much better now:
Nice to see them peek behind the AELLA front sprocket guard/cover:
