Well, turn out more parts and tools arrived (a bit later) today
First, the Brembo Billet Rear Caliper in Nickel Finished,...
so my Panigale V4 916 25 Anniversario was modified with many GOLD Theme Parts because the original 916 had that golden Magnesium Frame, Wheel, Brake etc...
basically making the bike look more RETRO
However, the 998s Final Edition was equipped with SILVER Frame, Silver Wheel and more subdue tone, so I want to keep that 998s FE theme by using mostly SILVER or NICKEL finished on this project.
Well, unless the part is really magnesium then...  that is why this Brembo Nickel Plated finish was choosen. I also plan to use a NICKEL plated front caliper, perhaps the GP4-MS.
Because I actually want to make the 998s FE to look more MODERN
EVR Carbon Fiber Radiator Fluid Reservoir because the stock plastic will crack due to age, plus this will match with the upcoming EVR LARGER Carbon Fiber Airbox:
Scotts reusable BILLET oil filter, beautifully made... I wonder if they have a version for the Panigale V4, I need to check
Nichols, Double Flywheel Nut to make sure it won't become loose, which is a tendency of Ducati stock single nut system:
Since I plan to change the flywheel with lighter flywheel from K-Bike, so I need to buy the Special Tool to replace the flywheel from K-Bike and this tool is HUGE
AELLA locking pin to match the still on the way AELLA 12 points Titanium Rear Axle nuts:
AEM Titanium Steering Hub Nut, and yes, they have a lot of scratches, but I actually expected this scratches due to my experience with buying the titanium steering hub nut for  my Panigale V4,...
it seemed that machining Titanium with this intricate of details is not easy... so I plan to just hand polish them myself... (and if not good enough, I will send it to a professional polisher)...
Oberon Clutch Slave Cylinder in Silver color, because again for the 998s FE, the theme is SILVER
How about some RED in between though, well, this is because for the Crankcase breather, STM only produce them in Red so I take red like Ducati Red
More K-Bike tools for the Cam Pulley and Timing Belt, plus other engine related tools:
Kbike Cylinder Head Nut tools:
continue below
