Some few small things I did last weekend was installing 2 ProTi bolts to cover the unused bolt holes for the original factory license plate bracket:
Install the ProTi Titanium bolts that hold bolt Motocorse silencer together:
And replace the regular hex socket bolt that came with Motocorse Rear Brake reservoir with the ProTi Torx Titanium bolt:
Below picture shows comparison between the regular hex socket bolt that came with Motocorse brake fluid reservoir to the ProTi TORX version:
I also finally able to install the Ducati Performance Carbon Fiber Clutch Cover (Satin clear coated) because the right length ProTi titanium bolts finally arrived:
Yes, they look PERFECT :
