I believe the safest map will always be the factory Ducati Akrapovic map, eventhough it might not be the map / tune with the most horsepower.hi,
im new to the forum and also thinking to start my build series here to share progress from the beginning.
Im currently concerned on the issue that Termi D184(low) and Upmap has very poor idle and it seems that they even removed the map from their store at all.
Has any of you somehow faced the same problem?
Has any of you tried Akra(low version) V4 22 AK FRL TRACK - UpMap - Need 4 Power ?
I really doubt that back pressure is that much different on Akra(low) and Termi(low) and if the Akra map is better maybe worth to try?
That was why I bought a full system Akrapovic exhaust system just to extract the map, for my bike which uses the SC-Project WSBK under-tail exhaust.
I agree with you, there won't be much different between Akrrapovic lower version and Termi lower version, as long as they are both the same full system or the same slip-on system.
