kneedrager
What do you mean by Daniel 's full kit?
He offers a kit that includes a wiring harness and 4 lambda sensors, and integrates with an AiM Solo 2DL, in addition to his handheld tuner.What do you mean by Daniel 's full kit?
Damn. I hope they get you taken care of.4 wide band sensors?
I'm in the middle of a band experiance with Superbike Unlimited. I ordered a Lightech fuel cap so I could use a Ripper fuel can top, and their online listing had the wrong part number per model bike. I sent an email explaining all this...that I needed to return it and what the correct part number was. Crickets. Call and spoke w Eddie, he said he was going back and forth with LighTech since the older part wasn't availible, but he'd get me a return authorization. Weeks later...I ordered the correct part and have it installed and it works perfectly with the Ripper.
I need to call again I suppose but an email and phone call later, I still need to call again. Its just annoying.
Hi Daniel,Hi guys, thanks for the invite! I am already part of your community here as a quiet reader. I just did not stop by in some time.
What I did offer to Craig was my handheld flasher (now also stocked at a US-Arizona based business partner) plus a CAN-Bus based wideband O2 Kit utilizing an AIM Solo2 DL as a logger and my remote tuning services. On the bike side, this setup requires someone with some sound technical knowledge and preferably a dyno with load control for the tuning process. It is also not a cheap solution. In total we are looking at $3500 for required hardware (Flasher, Solo2 DL and 4xLambda Kit) and my remote tuning services.
Going cheap with only a single wideband sensor will not save anything as the tuning will take much longer and as everyone knows: time is money.
Welcome Daniel!Hi guys, thanks for the invite! I am already part of your community here as a quiet reader. I just did not stop by in some time.
The EVO2 package consists of Dash+BBS+ECU software. Dash software is not needed as there is not actualy functionality running inside. If you get the BBS and ECU flashed, you will have EVO2 functionality. Currently the handheld flashers I use can only flash the ECU. I am working with the flasher manufacturer hoping they can combine both protocols into the flasher together so you can update ECU and BBS with a single device. I can already update BBS modules here on-site or any of my FlashPoint business partners can also do it directly on the vehicle.In my case : I am running at SST1000 in my country (i know we are 1100 but ok ...), 3500$ is more expensive than what i would like to invest on ECU mapping because i am gonna spend too much money to turn my V4 2020 into a track bike. Also for me its more important the correct - track setting of DTC, DQS , etc, thats why i am asking many things about DTC EVO 2.
After that said i am trying to find the best value for money for ECU mapping and i think after all the info that i have that i need to go with the official Ducati map for full titanium Akrapovic exhaust (to be honest i dont know the price yet because the exhuast is used and i have to buy the map).
If I am wrong please correct me guys.
Then some people are more lucky than some others... Since i am located in Greece all these are like a fairytale for me. I am still looking to find out what i can do.The EVO2 package consists of Dash+BBS+ECU software. Dash software is not needed as there is not actualy functionality running inside. If you get the BBS and ECU flashed, you will have EVO2 functionality. Currently the handheld flashers I use can only flash the ECU. I am working with the flasher manufacturer hoping they can combine both protocols into the flasher together so you can update ECU and BBS with a single device. I can already update BBS modules here on-site or any of my FlashPoint business partners can also do it directly on the vehicle.
There is a small drawback with not updating the Dash. There will be an error code in the BBS as it checks for compatibility with the dash software, and it will turn on the yellow triangle in the display. The solution I have found is to modify the BBS mapping so that the stored code will not turn on the yellow triangle in the display. I can do this now for basically any code that the BBS would detect like taillight and brake light.
You need to consult with either SLR/Bren/Rexxer whether their ECU flash is compatible with DTC EVO2 or not.I didn't knew that. Then the only thing that I can do is to buy the DTC EVO 2 from Ducati and then use a handheld flasher like SLR, Bren , Rexxer etc.
Daniel is in GermanyWell I want to say thanks for all once more. The forum is very helpful.
1. Is there any Daniel's partner in Europe?
2 SLR and bren still not flashing the BBS
3. Since most of them use as base the official akrapovic map then I could 1st flash the ECU and then go to a dealer to install the EVO 2.
The Akrapovic update from Ducati seems just fine in my ‘21 SP with the full system, low outlets. I also have Daniel’s tune map waiting for me to flash the bike.hi,
im new to the forum and also thinking to start my build series here to share progress from the beginning.
Im currently concerned on the issue that Termi D184(low) and Upmap has very poor idle and it seems that they even removed the map from their store at all.
Has any of you somehow faced the same problem?
Has any of you tried Akra(low version) V4 22 AK FRL TRACK - UpMap - Need 4 Power ?
I really doubt that back pressure is that much different on Akra(low) and Termi(low) and if the Akra map is better maybe worth to try?
