This is a GREAT idea ! I always wonder, how to easily retrieve the side stand plates after you sat on the bikeMade up a couple of sidestand plates / cords. Bought some paracord, aluminium ferrules and some cord locks. Used a hydraulic press to compress the ferrules and lock them in place. Loop end goes over the handlebar grip and tightens using the cord lock. When you want to set off, loosen the cord lock and remove the loop end from the handlebar and retrieve the sidestand plate using the paracord, so no need to bend down to pull out the plate from under the sidestand, once you are on the bike. Figured I would make up a pair, one for me and one for the wife.
Who did the paint job? Would they allow me to ship them fairings to paint? That clear they use is phenomenal. Carbon fairings tend to chip pretty easy from stone and debris, even if ppf’d. Do they use a high impact clear coat?Here are some high resolution images of the bike with its clothes finally on, as promised.
Pretty
The White Brembo logo is so so much better than the black Brembo logo. The red and clear coat paint is also very niceHaving collected the calipers from the paintshop yesterday, I spent an hour or so carefully refitting the spring plates, pads and Stahlbus bleed nipples to the front calipers. As standard these "Rosso" Stylema calipers supplied by Ducati, are only available with the Brembo logo in black, one of the principle reasons I had them repainted, so as to match the colour of the logos on the bike. The etch primer, paint and clear coat used, were all specially ordered in and are heat resistant (rated to 482C) to prevent any degradation or changes in the finish or colour. Now I've just got to fit and bleed them, then it's on to the rear.
I hope you will feel better soon and Rear Caliper also looks gorgeous.As I have a couple of days off work, I was due to re-assemble the rear caliper, fit and bleed it, but finally after two years of dodging the bullet, managed to catch Covid and woke up feeling rough as a badger's a$$ this morning, so if I can swallow enough paracetomol over the course of the weekend, I will give it a go. Give's me something to do while my employer imposes a 5 day isolation period before I can return to work (assuming I test negative by then).
