Saturday Delivery from Mr. Postman just arrived :
From Addiction Motorsport in UK (buy through their eBay store), the Aluminum Front Brake Caliper Spacer in 17mm and 18mm.
For this 2 sized, they only offer in Aluminum and not Titanium, at least in their website and eBay store, beside I purchase this only for "TEST FIT" and I will try to find the right size in Titanium (or custom made).
So if you are using FGR300 forks with 320mm diameter rotor, the spacer thickness is 12mm, which mean for our 330mm caliper the thickness should be 17mm. But just in case and since this aluminum spacer is not expensive, I decided to buy 18mm too just to be sure.
Also, I don't want to custom made a Titanium version now because I am not 100% sure if the newer version of the FGR300 forks (should be available by this November at EICMA, Milan show) will have the same mounting distance requirement.
So, I rather wait.
17mm set on the left, 18mm set on the right
Notice they have the "bolt hole alignment notch" on both side of the spacers:
So, I rather wait.
