DriveTrain upgrade project:
AEM Factory D-SEI V4 Sprocket Carrier in Titanium Color arrived. They are very beautiful. The right picturecompare it with the current original Sprocket Carrier.
I think this would be a good color combo with my EK 3D Gold Chain, Sitta Quick Changer and Sprocket, AEM Factory Titanium Studs (with Champagne gold rear aluminum housing), ProTi gold sprocket nut and AELLA Titanium Axle nut.
View attachment 270View attachment 271
AEM Factory Titanium Studs/Nuts with Cush Drives:
But, I want it to look even nicer, so I UPGRADE the AEM Titanium Nuts with MOTOCORSE Titanium Nuts:
EK 3D Gold Color 520 Chain:
And of course SITTA Quick Change Sprocket Kit:
View attachment 275View attachment 276
I am hoping to install all the above tomorrow as in September 20'2020, although I received all the above parts about 4 months ago, however, all the other modification require the whole rear swing arm, rear subframe, rear exhaus manifold and rear suspension to be removed, thus I can't install all the above yet... but hopefully tomorrow...
Hi Apuca,Howard, what was the color you selected for the AEM factory cush drives?
| AEM FACTORY - 6 DUCATI TITANIUM CUSH DRIVES WITH TITANIUM NUTS - Color: CHAMPAGNE | DU011T-CH |
Beware I had the very same Motocomposites exhaust shields and they discolored and burned badly. Perhaps if you added more heat shield to the inside it might save them but mine got toasted pretty quickly. First the resin got cloudy and eventually it yellowed/browned to a singed color. Got brittle and cracked around the mounting holes also.My custom exhaust.![]()
A016738 Thank you for telling me.Beware I had the very same Motocomposites exhaust shields and they discolored and burned badly. Perhaps if you added more heat shield to the inside it might save them but mine got toasted pretty quickly. First the resin got cloudy and eventually it yellowed/browned to a singed color. Got brittle and cracked around the mounting holes also.
Motocompoites was excellent about it and refunded my money and pulled the product from their site immediately. If it's back on their site maybe they added more shielding or something.
But if I were you I'd add some additional shielding and keep an eye on them.
I added the Ti gates myself because like you I felt they needed a little something to dress them up.
View attachment 3920View attachment 3921View attachment 3922View attachment 3923View attachment 3924
Beautiful piece! Did you happen to compare weights? I understand it's not a big deal and will be insignificant but I'm just curious given one is stamped steel and the other is billet aluminum.Mr. Postman just deliver the Panigale V4 SUPERLEGGERA Radiator Cap, Beautiful in every way
View attachment 3938View attachment 3939
View attachment 3940View attachment 3942
Mr. Postman just delivered a box full of exciting Panigale V4 SUPERLEGGERA parts and that made me ahhhhh sooooooo H A P P Y:
First for the people who change their exhaust and want to remove their servo system completely,...
Well, The Panigale V4 SUPERLEGGERA came with a BRACKET that only hold the ABS but eliminate the lower section where it hold the Exhaust Servo and I have it on my hand ready to be installed soon:
The right picture show comparison to the stock BRACKET:
View attachment 3128View attachment 3129
For the people that upgrade their REAR Brake Caliper... well I believe this V4 Superleggera caliper bracket (which is the same item as the older non V4 Superleggera bracket) might be the "finishing touch"
There is just 1 catch, it relocated the position of the caliper further below so you might need longer brake line and honestly, I am not 100% sure this will fit or not, so I am risking my wallet here
But I will find out soon and even if it doesn't fit, it will look good in my future display rack
View attachment 3130View attachment 3131
And then... for people who prefer upgrading parts from Ducati own's part instead of aftermarket part (like me), then you can consider the V4 Superleggera Carbon Fiber Instrument Cover...
Please note that I already had a complete set of Carbon Fiber instrument cover from Ilmberger and they are beautifully made, but when I found out that Ducati (factory) also sell this V4 Superleggera Carbon Fiber Instrument Cover to general public,
I can't help myself but buy them... after all they are Ducati original parts (eventhough they are manufactured by outside contractor, probably Ilmberger) but that "Ducati label" brings value for me (personally) and they also came from the V4 Superleggera
Back to the carbon fiber instrument cover, note that the Ducati Superleggera V4 version has slightly more glossy finish (it still matt but have that extra "SHEEN", than the Ilmberger version, almost like the Peter Lieb's carbon finish...
This also means, I will be selling my Ilmberger Carbon Fiber Instrument Cover soon because I don't need 2 sets of Carbon Fiber Instrument Cover
View attachment 3132View attachment 3133
View attachment 3134View attachment 3135
Of course, I will not forget to buy the lower mirror holes cover from V4 Superleggera in Carbon Fiber too
View attachment 3136View attachment 3137
I almost buy the left and right air channel (near the side fairing) and the ignition key cover, but the Superleggera V4 had different design than my bike so they won't fit... so I am unable to replace those with Superleggera V4 version and will keep the Ilmberger left and right carbon air channel and Peter Lieb's carbon ignition key cover... so before you start buying other parts from V4 Superleggera parts catalog, make sure you really pay attention to the drawings (and bolt mounting holes) to make sure it will fit your bike
Ok, now move to V4 Superleggera Carbon Tank Cover Painted in V4 Superleggera RED. Long time ago, I had this idea of buying a V4 Superleggera PAINTED Red Tank Cover because I suspect they are made from Carbon Fiber material due to the same "VENT SLATS" just like the raw unpainted Ducati Performance Carbon Fiber version. However, a person who purchased a V4 Superleggera told me it will have different shade of RED compare to my bike... plus the fact that at that time the V4 Superleggera just launch and no parts were for sale yet...
So I end up buying Ducati Performance unpainted Carbon Fiber Tank Cover thinking of painting it RED to match my bike...
Fast forward to present, and I noticed the V4 Superleggera Painted Tank Cover is now available for general public and I just bought it, thinking... if V4 Superleggera can have something like 3 different shades of RED paint, why I can't have 2 different shades of RED
This is America a FREE Country, so I bought it and picture below, oh, and I actually wasn't sure if they are CARBON FIBER, and boy, I am so happy when I found out that they are REALLY made from CARBON FIBER !!!
View attachment 3138View attachment 3139
The RED is BEAUTIFUL too and below is comparison with my 2 other tank covers, the original 916 version on top, and V4 Superleggera below it and Ducati Performance at the bottom:
View attachment 3140View attachment 3141
These are comparison of the RED color only:
View attachment 3142View attachment 3143
and the last part in this shipment is... The V4 Superleggera CARBON Fiber INTAKE below the HEADLIGHT, I know another after market carbon fiber part manufacturer made the same parts, however, I heard about horrible finish and fitment issue...
well, that should not be a problem with original Ducati OEM part and the finish... ah the finish just beautifully perfect:
View attachment 3144View attachment 3146
Test Fit, yap still PERFECT![]()
Now, I still have even MORE V4 SUPERLEGGERA parts coming, but they are currently still on their way here... hopefully they are not missing though because those parts cost even more than all the parts above...
I hope the next batch of V4 SUPERLEGGERA parts will arrive soon as they are also quite spectacular (at least that is what I am hoping they will be)![]()
