Hello Pomplardpanam
Here are a couple pics of my pants. I think these are called Dainese Speed pants or similar. I have had them since late 2012. I have put the patches in the centre of the photo. If you look immediately above the calf area where the black material is you will see the square leather patch on both sides. This patch of leather has been sewn over the original leather with a double layer of 100% wool blanket sewn in between. So leather then 2 layers wool then anther outer layer of the black leather. No heat problem anymore. It was always just behind the knee on the back side of the thigh that got hot for me.
I tried reflective heat foil under my seat. Did nothing. I tried running McCool in the radiator. Did nothing. I have a full Akra Evolution exhaust Ti system. Did nothing for heat. (not that I thought it ever would), however other people suggest a free flowing exhaust would make the bike run cooler. Maybe it does, one or two degrees but nothing you can feel on your legs. I purchased the Akra for the sound and the saving of almost 6 kg in weight over OEM.
The only way to fix it is get much bigger radiators or protect yourself against the heat. IMHO. (In my humble opinion). It worked for me and was cheap. Wish I did it back when I first got the bike.
By putting a patch on just the area where the heat comes thru to your skin you are not making all of the pants double thickness and so other areas remain more comfortable. If I ever get a nice race suit to wear I will get the same mod done.
cheers
PS having trouble uploading the pics as to large. I think am doing something wrong. Happened last night as well. It will be my poor computer skills.
Will post the pics once I work out what I am doing wrong.
OK. BMWAlpina came to the rescue and told me what I was doing wrong so here we go again. Second time lucky.
Ok first pic show the patches on the back side of the thigh. You can see it is hard to tell there are patches there as they follow the line of the standard stitching
If you look at the second image you will see the corner of the patch indicated by my thumb. The inner line of stitching is the patch. Look carefully and you will see it is not as straight as the factory dainese stitching. Underneath that smaller square patch is the 2 layers of wool. The second photo is the lower left corner of the back of the right pants leg.
