With the 'back-end' almost complete, it was time to focus on the front subframe, the remainder of the wiring, instrumentation and lighting. Up until this point, no power had been applied to the bike, and with so many sensors disconnected and disturbed, plus some additions and modifications to the original loom, it was always going to be a heart-in-the-mouth moment that everything worked as described, when I turned on the ignition. I wasn't planning to run the bike at this stage (that would have to wait until the fuel tank was back on), just check the basics functioned as intended.
First step was to re-install the two part 6-axis Bosch IMU accelerometer with new fasteners. It's important not to apply any power to this unit until it is in it's correct orientation on the bike, else I am reliably informed, it can throw it out of kilter.
Instrument panel re-fitted. You can also see the "silent-block" as Ducati call them, rubber dampers that help locate the 2 IMU units onto the subframe.
The two leads from the bar-end indicators in the centre of this image, are routed underneath the top of the subframe and will connect to the loom just as the original OEM mirrors/indicators did. Under the top yoke, you can also see the white connector that will eventually connect to the electronic steering damper
I applied a "Speedo-Angels" anti-glare film to the face of the instrument panel, partly to, as the name suggests, reduce glare but also to prevent scratches. It's easily removed and replaced if needs be.
The plastic instrument cover on the V4 is normally a one-piece moulding with enough give that it can be bent into position as it sits astride the sub-frame casting. Owing to this, there just isn't the scope to make it in a single arrangement, so it comes in three pieces, with an additional three parts supplied as part of the kit, two that bolt through the subframe into the nose fairing (mirror caps) and a GPS blanking plug.
GPS blanking plug
Mirror caps and blanking plug
Side panels of the instrument cover kit
The side panels need to be fitted first
These are then sandwiched between the subframe and the main front cover
