I've never been a lover of the antennae-esque rear view mirrors on the Panigale, less so their fragility, the fact that on the V4, unlike the 1199, they don't fold back and perhaps more importantly, that they vibrate so much they are near next to useless in the real world, so a decision was made very early on, to get rid of them altogether and go with bar end indicators. I don't like the type that bolt to the nose fairing so it was an easy choice.
The difficulty lay in how to wire them up. Since the handlebars have allen headed inner end caps that secure them to the clip-ons (see previous post for images) the wires from the indicators would have to exit before this point. I simply drilled a small hole on the underside of each handlebar, just before the bar enters the clip-on casting, which is where the wire will exit. I measured and drilled these out some weeks before I had the bars Cerakoted. Having worked out how to get the wires out, I now needed to find a way to connect them to the existing points on the loom. For this I grafted/soldered on two OEM style indicator connectors and fly leads to the exiting wires and heat shrank them, before finally covering them in braided hose to blend in with the style of the OEM loom. These two leads would then loop across to the centre and down over the top of the air filter duct and under the front subframe where they can connect to the original indicator connectors on the front end loom. I tested this set up many times to ensure there was enough slack in the wiring to allow lock to lock movement of the handlebars without the wires being pinched or snagged in any way or that would place them under any tension.
The indicators themselves....I went with MBlaze by MotoGadget, a German manufacturer. I like the narrow form factor and size, as they barely add to the length of the handlebars unlike the Oberon units I had on my 1299. They are incredibly bright and because I wanted to fit them in conjunction with bar end mirrors and MotoGadget don't make a kit for them, I had the retailer (DesmoWorld in Germany, huge thanks to Chris Schipfer for this) make me up some one-off anodised billet adaptors. Not cheap but worth it.
Custom made mirror mounting adaptor kit
Indicators as supplied
Cable sheathing, heatshrink and mirror mount adaptor fitted
OEM connectors fitted onto the ends of the indicator wires AFTER fitting and complete indicator assembly BEFORE fitting to the handlebars
Indicators fitted to the bar ends. The MBlaze model indicators are handed, so MotoGadget sell both a LH and RH version, which are sold separately. This is due to the orientation of the LED bulbs inside. Whilst they are omni-directional in terms of light output, they are brightest when viewed directly in front or from behind, so have to be angled accordingly taking into account the pitch of the bike when sitting on two wheels
This final image shows the "glass-less" mirrors, which I will be fitting later in the build. They feature a unique diamond cut and polished metal disc that produces a reflective surface on par with a conventional glass mirror.
