Last week, I tested the CNC Racing steering damper bracket. Please note that this CNC Racing steering damper has been enlarged from the original 53mm diameter to 54.5mm diameter to fit the RVP 25 forks.
However, I forgot to ask for it to also be "chamfered," so it was having an issue during the initial contact to fit the Ohlins RVP 25 forks.
So I used Dremel to chamfered the corners:
Then I get rid of the rough surface step by step using light sanding and finally polishing tools to get them to mirror polish:
Now they fit well to the RVP 25 forks:
But as @bp_SFV4 pointed out before they were not long enough so the Ohlins steering damper is not position straight in relation to the upper triple clamp:
They still will works, and the steering will still have enough play from lock to lock in my case, but they need to be about 1 cm longer as shown in the picture below (to make them perfect):
So I will do something about this soon
