AgreedThe trouble is see if the weight on the site is right its not saving much. The factory one without bearings is around 800g. So you save 60 grams for $700. You know I love saving grams but this one doesn't make much sense.
Spot on HK. It was bugging me as I chased a magnesium version previously. I dug thru my old email and found a message from a good friend who got a RAM hubThe trouble is see if the weight on the site is right its not saving much. The factory one without bearings is around 800g. So you save 60 grams for $700. You know I love saving grams but this one doesn't make much sense.
I just ordered one, i need a new Hub so thought I would give it a go, there's a 4 week lead time so i will do some weight comparison when it arrives.The trouble is see if the weight on the site is right its not saving much. The factory one without bearings is around 800g. So you save 60 grams for $700. You know I love saving grams but this one doesn't make much sense.
Thank you for the kind words @KODAKHODAK ,I have to admit, this build is incredible, the amount of Titanium bolts replaced is mind blowing, do you know what the total cost of your bolts replacement and how much weight you saved from factory standard?
Still very impressive on the amount of detail you have poured into this project, I guess it becomes addictive at bestThank you for the kind words @KODAKHODAK ,
I did not count the cost of the Titanium bolts and I also did not weight the weight saving.
The Weight Saving maybe not really too much, but the satisfaction of a MODIFIED Ducati is what make it worth it for me
I was born just a bit after the original Kawasaki Z900 launch, made me feel old tooOuch! Was it 50 years ago my slightly older friend - I was still in school - shocked everybody by arriving at the church youth group on a spectacular new and very muscular-looking Z900. I previously had no interest in the bikes of those days. A long story but that bike indirectly resulted in me riding a V4S today. 50 years?! Jeez that hurts.
Good eye Pete, thanks for pointing that out, an under yoke stand won't work !!!Does a head lift stand still work with one of these?
Thanks for your kind words ferociiousAbsolutely beautiful build
By the way,
I am checking Motocorse website every day because I am waiting for the lower triple clamp for our Panigale V4 and Streetfighter V4...
Today I saw a new triple clamp, unfortunately it is for MV Agusta,.. but if the triple clamp for our V4 going to look like this version for MV Agusta... wow... I for sure want it...
just take a look so beautiful:
Be nice if there was a good weight reduction as wellThat black DLC coated stem is amazing. That lower triple has some awesome cuts!
Great work well done HFinally have time to continue working on the custom Oil Cooler Hose today.
First, need to disassemble the factory Ducati shorter Oil Cooler Hose because I need the 90 degree fitting to the oil cooler:
View attachment 8407 View attachment 8408
Then cut the crimp using Dremel:
View attachment 8409View attachment 8410
Then extract the fittings on both ends:
Now time to test fit the Earl's Crimp:
View attachment 8412View attachment 8413
Use some oil to lubricate when inserting the Ducati Fitting to the Goodridge XF811 hose:
Then once inserted mark the alignment:
Do the same with the other end:
And now it is ready for test fit and alignment (orientation) adjustment:
Fit it to the oil cooler side first:
and routed the hose with good spacing to the exhaust manifolds:
View attachment 8419View attachment 8420
Then mark the alignment with paint so I can send them to be crimped:
And here is the final orientation of both ends:
Can't wait to get them crimped so I can start the engine again
