I was planning to spent this long weekend working on this bike, however, I just realized that my Honda Fit front brake rotors and brake pads need to be replaced and can't wait anymore, so this past 2 days were spent working on it.
In fact, I just return back from bedding the rotors and the brake pads (30mph for first few miles to take out the zinc coating, then 20 times braking from 60mph to 20mph plus 20 seconds cooling down in between and 10 times 80mph to 20mph with the same cooling down and 10 minutes coasting no braking).
Can only safely do it in the middle of the night... that is why...
However, I managed to used this to test the Ultrasound Cleaner for washing the brake rotor HATS and also some parts from my 998 project.
First, I warm the water up, and it start at 16 celcius to 45 Celsius (took around 40 minutes to reach 45 celsius).
I use Simple Green for aircraft application mixed with 3 parts water:
Put the parts to be cleaned, oh, I also put the old bolts and nuts in the plastic bag (later filled with the cleaning solution of course):
And here are the 998 parts and the Panigale V4 oil cooler hose fittings, quite happy with the Ultrasonic Cleaner:
By the way, here is the Brembo brakes on my Honda Fit Before and After the replacement, notice the Rotor HATS is very clean now (right picture) after Ultrasonic bath:
I also use Ohlins suspension on my Honda Fit, (built by Ohlins distributor in Japan, Carrozeria)
This Brembo brakes is originally a kit for the Subaru BRZ, but I designed (napkin drawing) a custom rotor Hat and Custom Caliper Bracket and sent them to machine shop to fit my Honda Fit.
The brake rotor on the left was originally have slots like the new one (they are Type III Brembo rotors), but after about 120,000 miles, they become a FLAT surfaced rotors
It's amazing though that I only have to replace the rotors after 120k miles and only replace the brake pads twice despite lots of heavy braking. (Well Honda Fit is a light and slow car that is why
Actually this second brake pads still have some materials left, but I figure while I replace the new rotors, might as well replace with a new pads for proper bedding,
and so I don't have to take out the brake calipers again for at least another 60k miles
Hopefully tomorrow I can use the time available to work on this bike
